Oil Temperature Gauge Substitute
02-09-2007, 10:03 PM
Who here has used a Water Temp Gauge as an Oil Temp Gauge? Any insights on why this would or wouldn't work are welcome and useful for people other than myself i'm sure.
![]() "Strictly All Things 86" |
02-09-2007, 10:06 PM
Cant see why it shouldnt work, both of my gauges uses the same sort of temp. sensor...
02-09-2007, 10:21 PM
Knudsen Wrote:Cant see why it shouldnt work, both of my gauges uses the same sort of temp. sensor... my thoughts exactly, but i'm of the opinion of looking both ways before crossing the road ![]() i appreciate it Knudsen |
02-21-2007, 01:13 AM
Oil temperatures are usually higher than water temps, so the gauge might go off scale.
02-21-2007, 07:54 AM
A fair point, Ferret, but there is the question of the sensors themselves - if they emit the same signal on the same t°, then you are absolutely right...
02-25-2007, 07:14 AM
Ferret Wrote:Oil temperatures are usually higher than water temps, so the gauge might go off scale. true and also, the water temp gauge may say "water temp" on it and that'll be annoying. ![]() |
02-25-2007, 02:40 PM
domi Wrote:A fair point, Ferret, but there is the question of the sensors themselves - if they emit the same signal on the same t°, then you are absolutely right... I assume that the water gauge sender is used. If a different sender is used, then the gauge won't read accuratly. |
EUDM gauge cluster | banpei | 22 | 8,670 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 9,530 |
Analog gauge cluster tech | Ivan141 | 33 | 48,022 |
01-31-2016 11:06 PM Last Post: Bean |
Original gauge with universal fuel sender | Komba | 4 | 7,398 |
01-05-2015 03:27 PM Last Post: Komba |
trans oil, lsd oil change | Apolan | 9 | 19,456 |
