Oil Pan Issue
01-05-2016, 11:15 AM
Oil Pan Issue
Hi all,
Long time since I posted on here. About two years ago I purchased a new oil pan from these forums. I'm having to replace my sump plug washer as it's leaking, but strangely the plug/bolt is an m14...so i've made a mess trying to replace it with what it should be...a m12. Has anyone else had this issue? |
01-07-2016, 02:08 PM
Oil Pan Issue
What type of washer are you using? I´ve found that a fibre washer will solve the problem 99% of times. copper and aly washers leak!
01-07-2016, 02:11 PM
Oil Pan Issue
Hi,
I don't know what washer is on there but I need to replace the bolt. So my question is, why is there an M14 instead of an M12 present? |
01-08-2016, 10:05 AM
Oil Pan Issue
IIRC, the oil drain bolt is a different size for FWD 4AGE's and RWD ones.. my original AE86 bluetop had a bigger drain bolt than the AE92 bigport that replaced it. Just get the correct size washer and you're OK.. How did you intend to replace that bolt, and why should it matter?
01-08-2016, 12:14 PM
Oil Pan Issue
Ahhh I did not know that. I assumed it was going to be an M12
01-08-2016, 07:46 PM
Oil Pan Issue
I'm almost sure that there were only M12X1,5 and M18X1,5 threaded oil pans from the toyota, so probably it had a bad thread before and someone drilled and tapped it oversize.
01-11-2016, 04:50 PM
Oil Pan Issue
It was a brand new sump.
| PWR light issue and no brake fluid after winter storage | magpie | 10 | 8,251 |
| Fuel pump issue | DJexor | 11 | 12,013 |
| Clutch Issue | Deaty | 8 | 8,306 |
04-09-2021 10:26 PM Last Post: Nakilad |
| 5th gear issue | r.ave | 1 | 5,029 |
03-14-2021 08:52 PM Last Post: Ivan141 |
| exhaust odor/idle MOT issue | Ryo | 7 | 11,628 |
