Offset and wheels
02-10-2005, 12:44 AM
Offset and wheels
Becouse I got a problem with finding wheels for my Hachy, i found something interesting from T3.
http://www.technotoytuning.com/t3_site_p...pters.html What is your opinion about this. 32 mm thich resolve offset problem. How this thing effects on bearings and suspension. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
02-10-2005, 01:29 AM
Offset and wheels
It doesn't put more stress on the car. A lot of people say that, but that's just rubbish. What matters is how far the wheels are sticking out the car. Basicly a rim with ET 50 has the same effect as a ET 20 rim with a 30mm spacer.
The disadvantage of a spacer is that it may feel a bit loose/shaky at higher speeds. Beauty of the T3 piece is that you bolt it on both sides so it should be solid. If I can not get good rims then I'm going for these T3 spacers with a 4x100 pattern. Broken down 1984 Trueno HB
02-10-2005, 02:21 AM
Offset and wheels
Aico Wrote:It doesn't put more stress on the car. A lot of people say that, but that's just rubbish. What matters is how far the wheels are sticking out the car. Basicly a rim with ET 50 has the same effect as a ET 20 rim with a 30mm spacer. Errrrrr no. A rim with ET20 and a 30mm spacer will be effectively ET-10. Spacers are not ideal bevause you are adding rotating weight and putting extra stress on the wheel studs. They will not feel shaky at high speeds provided they are dual hubcentric fitting - ie both the spacer/hub and wheel/spacer interface is dead centred. Bearings and suspension are affected by how far away the wheel is, yes. This is due to a higher levarage or moment force (Force x distance). Highly offset wheels with spacers are a waste of time if you ask me - just get the correct offset - it will look better because it will be deeper/more inset and will be a safer bolt-up. |
| Billet 5X114.3 hubs adds 30mm offset | 4000GT | 0 | 4,903 |
01-30-2015 06:40 AM Last Post: 4000GT |
| DRAG dr54 wheels >> +15 offset >? help !! | geoscranny84 | 4 | 7,938 |
04-26-2012 09:31 PM Last Post: bozu |
| Help with wheel sizes and offset | bozu | 12 | 28,493 |
04-12-2012 05:39 PM Last Post: oldskull |
| Work equip 01 max offset?? | stalker | 5 | 12,035 |
08-23-2011 03:09 AM Last Post: Lewy |
| Max offset, max width. | hachirokuGTV | 7 | 16,869 |
06-10-2011 11:30 PM Last Post: DJexor |
