OST's E and R&D
05-11-2014, 06:36 PM
OST's E and R&D
Been doing a bit of experimenting (while waiting for the burette to arrive to replace the broken one from OST-026)
[Image: AEU86 AE86 - OST's E and R&D]
Later today I'll be removing the pours of OST-026's 1st 2 exhaust ports. Once that is done, I'll fit the valves into OST-026 and pour the chamber. While I do that I'll be pouring the exhaust port from the untouched head....
So... I guess.... more to come.... Hurray!
oldeskewltoy Wrote:Later today I'll be removing the pours of OST-026's 1st 2 exhaust ports. Once that is done, I'll fit the valves into OST-026 and pour the chamber. While I do that I'll be pouring the exhaust port from the untouched head....
First the clay is removed, and the valves come out....
Next I use a cork screw....
gradually working it free....
and viola......
The chamber of OST-026 was also poured...
and so was the exhaust port of the untouched head
more to come...... Hurray!
Dan -
05-11-2014, 08:15 PM
OST's E and R&D
Nice way to compare your job with the original! Thumbs up!
05-11-2014, 10:24 PM
OST's E and R&D
Good work, I think Jeff did something similar quiet some time back.
Sent from my Nexus 4 using Tapatalk
AE86 ex-daily
05-12-2014, 05:49 PM (This post was last modified: 05-12-2014 06:00 PM by oldeskewltoy.)
OST's E and R&D
from another forum Wrote:Interesting... will you make molds/castings of each head you do work on starting with this one?
The supplies, and the time involved don't make it economically feasible to just add it ... BUT I am thinking of offering this as an additional service, for a fee
(05-11-2014 10:24 PM)Bean Bandit Wrote:  Good work, I think Jeff did something similar quiet some time back.
Jeff was doing the 20V intake ports... I'm not sure, but I don't know if he ever did any exhaust bowls/ports
(05-11-2014 08:15 PM)banpei Wrote:  Nice way to compare your job with the original! Thumbs up!
Thanks...
speaking about comparing the two.... Wink
The first thing I can tell you... the original exhaust is, without a doubt, a VERY good port. When I say I gain 3-10hp with my work... This port would lend itself to the lower side of my claim.
WHY?
The shape of the original port (bowls) shows a decent casting at both the short, and long radius's. They flow smoothly with little disruption. When I came across a head with nasty bowls, I'll cast it and post it, but for now you'll have to trust me... this original is pretty good.
So where do I gain 3, to lets say 5 hp in this head?
Part of it is in matching the valve seat to the bowl.... but the original design has a slight flaw........ It's "Y" shaped.... so the majority of where I improve the exhaust bowls and ports... even in a good casting... is where the bowls blend into the port......
I turn the "Y"... into a "V"... Less energy to navigate a straight port then one with a kink
from another forum Wrote:Any way we could see a atlantic ported head, chamber and ports.
I can ask Loynings... but I have a feeling they don't like to reveal as much as I'm willing too.... Huh
Dan -
05-12-2014, 08:50 PM
OST's E and R&D
Exactly what I was aiming at... Wink
Nice job on the porting! Thumbs up!
  lowering - adj. panhard rod & rca's & panhard bushin Apolan 8 10,111 05-24-2009 10:20 AM
Last Post: Apolan
  Is this diff whine and r&p or drive shaft bearing proble oli 60 70,987 10-31-2006 05:57 PM
Last Post: oli
  Tokiko Hp & Eibach & Cusco 1.5 RS & koni Sport Abe 8 9,671 05-17-2006 04:30 PM
Last Post: Abe
