OEM Distributor w/Heatshield for an AE86...
06-29-2007, 05:11 PM
Tired of melting your distributor cap? Want a heatshield for your AE86 distributor? Don't want to buy a crappy one from Aerodyne? Want OEM quality?
There is a solution, get a distributor from an 85-87 MR-2. (The 88-89 MR-2 may also work, but I have NOT personally confirmed it. BTW - did the first 4 sentences sound too much like an infomercial, or is it just me? Wink )
They come with a 4AGE bluetop just like the AE86, but it has a slightly different distributor. The MR-2 distributor housing, and distributor cap are different. The housing has mounts for a factory equipped heatshield, and the cap angles upwards for more clearance in the MR-2 mid-engine bay. The internals, and rotor are identical. All you have to do is exchange them, you can even use your AE86 sparkplug wires by looping/routing them a little differently.
[Image: AEU86 AE86 - OEM Distributor w/Heatshiel...an AE86...]
Andrew
p.s. Yes, I know. This is pretty common knowledge, especially for those of us that have been around a while. But I figured it would be good to give information/confirmation to those looking for relatively cheap OEM options/upgrades. Who haven't heard of this, or seen it for themselves.
06-29-2007, 11:28 PM
Nice cam cover...
Keeping the AE86 alive!
06-30-2007, 02:44 AM
what the hell is goin on with cylinder 4 extractor?? is that some kinda bracing??
At last Itsuki is gone.....:o)
Who the hell is Itekani??
lol...Wataru! ????
06-30-2007, 08:03 AM
Exhaust gas recirculation
07-01-2007, 12:51 AM
assassin10000 Wrote:Don't want to buy a crappy one from Aerodyne? Want OEM quality?
Nothing wrong with Aerodyne....
Dan -
07-02-2007, 09:33 AM
oldeskewltoy Wrote:Nothing wrong with Aerodyne....
I have one too, thought that myself and it was fine for me. Right up until I found out that from removing & installing my distributor several times the 'cheaper' metal they used to make the shield split on both mounting ears where the bolts go through.
Andrew
  16v distributor hole plug harkes 8 12,129 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 20,676 07-04-2016 03:27 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 24,542 07-01-2013 11:08 PM
Last Post: pack
  ae86 oem lsd Captainl 3 6,505 07-05-2011 08:48 AM
Last Post: Captainl
  weak spark. new distributor? please help. stasis_dc5 3 8,804 04-11-2011 12:35 AM
Last Post: fax0815
