4age W series bellhousing adapter
02-12-2008, 01:22 AM
For some reason I can't seem to find a whole lot of info on using a W55 or 58 behind a 4AGE motor. I want to swap a 4age into a Suzuki Samurai and want to use a very common W trans instead of trying to locate a T50.
I contacted Glenn Barker at the Castlemain Rod Shop. It would be more than $700 US dollars shipped to New Hampshire. Plus he has only done one for a 4AGZE (which I imagine would have the same pattern) I've read not to mess with Demellos (spelling???) bellhousing. Who is left? Anyone in the states make this adapter? If not, who would you go to to have both bellhousings welded into one? I'd rather run the 4age than a Nissan CA18DET but the 240SX have a good RWD tranny already in the deal when you buy a JDM swap motor. Any help in located a W bellhousing adapter would be appreciated, thanks |
02-12-2008, 10:03 AM
Irishtwincam should be able to help you, I've got one on order from him.
02-17-2008, 04:18 AM
How much was it?
sharing knowledge - RX7 brake adapter | aussiefan | 5 | 12,797 |
04-18-2025 05:21 PM Last Post: Gintrapper |
4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 8,096 |
09-30-2016 03:38 PM Last Post: The Doctor |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 9,413 |
1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 8,145 |
06-15-2013 12:34 PM Last Post: S.K. |
Which shifter position on W series box? | 4000GT | 3 | 9,913 |
01-27-2011 12:17 PM Last Post: assassin10000 |
