No dashboard light after retrofitted xenon lights
02-21-2008, 08:08 PM
Hey,
I've installed an xenon conversion kit on my Levin, and that works fine... However the light in the dashboard does not work...
Any ideas on how to fix this?
84' Corolla GT Twin Cam AE86 (daily driver)
02-21-2008, 11:20 PM
Does the rear lights work? Its the same fuse...
[Image: AEU86 AE86 - No dashboard light after re...non lights]
02-22-2008, 06:05 AM
you need to add a resistor in the wiring loom somewhere, because the resistance of the Xenon at high beam is to low to let the light in your dashboard ligth up.
Only thing is: i haven't got a clue where to add the resistor Tongue
02-22-2008, 10:40 AM
I think the Doctor is right but I wouldn't go for adding a resistor, I'd try to seperate the two circuits...
Somehow I think you should avoid using power resistors whenever possible, mainly because I don't find it an "elegant" solution, but also because it will reduce the voltage drop over the head lights and therefore dim them.
02-22-2008, 10:49 AM
I had the same problem here wit the AE101
what also will work, and you will see, if you fit a normal bulb in the spare empty socket.
I will come back to this later Wink with a more clear explanation
cheers,
Roel
  PWR light issue and no brake fluid after winter storage magpie 10 6,902 05-25-2023 08:09 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,685 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Digital speedometer on stock dashboard FanIsHere 0 2,943 11-09-2022 01:36 PM
Last Post: FanIsHere
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 14,020 12-19-2021 11:58 PM
Last Post: gh0st
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 9,968 07-31-2019 11:28 AM
