Nipples
04-11-2008, 10:16 PM
Nipples
Now I've got your attention... Big Grin
I have a problem with a rear caliper bleed nipple (screw) I know it just wants to break off before it unscrews. I have soaked it for ages in penetrating oil but still no joy.
There is no fluid in the system as I have just fitted new pipes so heating it is not a problem, I'm even considering mig welding something to it basically to get plenty of heat. What does everyone think ?
I have a rally imminent and can't afford the time to break it off inside Huh
Thanks
04-11-2008, 10:30 PM
Nipples
i would go for heat,a few times what weve done is get the nipple real hot then spray some wd40 on it,breaks the seal in the thread
not 100% guaranteed to work but 9 out of 10 its worked
[Image: AEU86 AE86 - Nipples]
04-11-2008, 10:39 PM
Nipples
I only have a rather large canister type blowtorch, do you think it would work or should I break out the welding gear ?
04-11-2008, 11:06 PM
Nipples
i use a blowtorch, i think welding might distort the thread,then its had it and needs drilling and re tapping
04-12-2008, 08:49 PM
Nipples
Had a go at it this evening, blowtorch and WD40 and it gave in Hurray!
a bit scary though, for all the world it looked like snapping off.
Thanks for all advice offered Thumbs up!
04-12-2008, 09:04 PM
Nipples
excellent
04-12-2008, 10:33 PM
Nipples
now put some copper grease on it before re-installing it!
  Bleed nipples totta Crolla 4 7,559 07-25-2009 02:08 PM
Last Post: totta Crolla
