New overheating problem
02-25-2007, 06:26 PM
Bought a new thermostat and radiator cap this weekend, I'll fit them this week and see where that takes me.
03-08-2007, 08:44 PM
I've had the new radiator cap on for a week now, it hasnt overheated since.. looks like it's solved Hurray!
Thanks for the input guys
03-29-2007, 05:22 PM
AArrghhhh...
Today I spotted a bit of fluid under my car in the parking lot.. felt and smelled like coolant so I checked the level, which was fine.
On the way home it started overheating again at the first traffic jam, so here I am at NoHachi's place waiting for the traffic around here to quiet down again so I can drive te car home without crawling.
A closer inspection revealed the bottom half of the radiator to be filled with coolant, and there is a small leak trail going down the side of the radiator.
the fluid level is still good, but y new radiator cap indicates that it has already been venting excess pressure.
I know I need a new radiator, but I find the symptoms a bit weird if it's only a leaking radiator..
04-07-2007, 10:59 AM
Sure sounds like the thermostat is not opening properly. But
a blocked radiator or partially collapsed radiator hose could
cause the same symptoms.
Have you put the new thermostat in yet ??
Cheers... jondee86
04-07-2007, 07:15 PM
Thanks for the reply... I've put in a new radiator&cap + thermostat in last week. This solved the overheating problem again, although I will need to replace the heater hoses and probably the radiator hoses too.
  Rear brakes overheating Blaze0010 3 1,502 10-03-2025 05:57 PM
  4agZe problem solved - 99% IC problem Okami 41 47,983 07-12-2012 04:49 PM
Last Post: Okami
  Problem with new window moulding Jimmi The Kid 2 7,084 05-13-2012 09:21 PM
Last Post: Jimmi The Kid
  4agze overheating ash16valve 5 7,977 07-24-2010 09:56 AM
Last Post: ash16valve
  AC problem? Idle problem? KD2229 3 6,383 08-19-2009 02:08 AM
Last Post: KD2229
