New overheating problem
02-25-2007, 06:26 PM
Bought a new thermostat and radiator cap this weekend, I'll fit them this week and see where that takes me.
03-08-2007, 08:44 PM
I've had the new radiator cap on for a week now, it hasnt overheated since.. looks like it's solved
Thanks for the input guys FABRICA MI DIEM, PVNC! |
03-29-2007, 05:22 PM
AArrghhhh...
Today I spotted a bit of fluid under my car in the parking lot.. felt and smelled like coolant so I checked the level, which was fine. On the way home it started overheating again at the first traffic jam, so here I am at NoHachi's place waiting for the traffic around here to quiet down again so I can drive te car home without crawling. A closer inspection revealed the bottom half of the radiator to be filled with coolant, and there is a small leak trail going down the side of the radiator. the fluid level is still good, but y new radiator cap indicates that it has already been venting excess pressure. I know I need a new radiator, but I find the symptoms a bit weird if it's only a leaking radiator.. FABRICA MI DIEM, PVNC! |
04-07-2007, 10:59 AM
Sure sounds like the thermostat is not opening properly. But
a blocked radiator or partially collapsed radiator hose could cause the same symptoms. Have you put the new thermostat in yet ?? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-07-2007, 07:15 PM
Thanks for the reply... I've put in a new radiator&cap + thermostat in last week. This solved the overheating problem again, although I will need to replace the heater hoses and probably the radiator hoses too.
| Rear brakes overheating | Blaze0010 | 3 | 2,043 |
10-03-2025 05:57 PM Last Post: banpei |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 51,885 |
07-12-2012 04:49 PM Last Post: Okami |
| Problem with new window moulding | Jimmi The Kid | 2 | 7,484 |
05-13-2012 09:21 PM Last Post: Jimmi The Kid |
| 4agze overheating | ash16valve | 5 | 8,496 |
07-24-2010 09:56 AM Last Post: ash16valve |
| AC problem? Idle problem? | KD2229 | 3 | 6,800 |
08-19-2009 02:08 AM Last Post: KD2229 |
