New Fuel Pump for the 4AGZE
11-23-2010, 09:28 AM
can that be an awnser for the little dip in my air fuel ratio?
I do not do not think so, because of the ok ratio at 7K RPM
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
11-23-2010, 10:35 AM
What dip? You mean the bit around 6,5k rpm where it goes pig-rich?
I think you are reading the graph incorrectly, it's air-to-fuel and not fuel-to-air, so a lower number indicates a richer mixture. You might be loosing power due to this judging by the dip in the power curve, although 12:1 is not extreme for a boosted car. FABRICA MI DIEM, PVNC! |
11-23-2010, 10:50 AM
It really looks like going 12 AFR instead of 13 costs him few HP. Hmm, interesting!
![]() Nevertheless, you have more than enough fuel Gtsi-R. |
11-23-2010, 11:35 AM
Below peak torque: more fuel == more power/torques
Above peak torque: less fuel == more power/torques... well.. until it goes boom. The number of 190l/h seems very high. 200hp is just 63l/h worth of fuel. Add 20% for charge cooling/boost, and another 30% bypass flow and that's still shy of 100 l/h. Could imagine a tired old pump ending up at that number..or maybe a system with clogged injectors/filters etc, but that shouldn't harm hp. Maybe its rated 125l/h at a lower system pressure? A wheel to steer the front of the car A pedal to steer the rear |
11-24-2010, 08:08 PM
Guys, I havent replaced my fuel filter either? You think there's a limitation on that too?
I still have the one from my old engine.. 20 + yrs old... Cheated on my いたずらな女の子 and now I can't get enough of her.. |
11-24-2010, 08:31 PM
heshan Wrote:Guys, I havent replaced my fuel filter either? You think there's a limitation on that too? ( Very unlikely. Can it redline 3rd without the plugs looking blistered, then it is OK, 'it' being the entire fuel system. Excess pump capacity will do nothing for performance and can hurt it, especially at idle, if it's overwhelming the capacity of the FPRegulator return. |
11-29-2010, 04:57 AM
allencr Wrote:heshan Wrote:Guys, I havent replaced my fuel filter either? You think there's a limitation on that too? ( I agree with Allencr, depending if you are going the turbo route in the future then Yes the Wallboro pump will be necessary but if you are going to keep it SC then No leave the pump and change the petrol filter. Current - 2006 Run X RSI TRD spec Current - 1991 AE92 Conquest 4AGTE Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM) Ex - 1983 1.8 SE Liftback(headworks and side draughts) |
12-03-2010, 07:18 PM
hmm.. so you're saying DONT put the pump ON? Damn almost put it on as it was told to be OK to put on..
On the Fuel Filter, wouldn't that also be a bottleneck for flow? Is there a good filter for this or just the stock one is fine? How's the Bosch Filter made for MR2? would fit this right? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
12-03-2010, 09:26 PM
Just slap it on and see what happens
You'll be fine. Fuel filter->almost anything will fit..the MR2 will most likely be fine and they cost peanuts.
12-05-2010, 05:53 PM
Ya I think I might.. also mechanic said it might be sufficient to clean the old filter and put it back on..
thanks guys for all your input .. this is great!! Cheated on my いたずらな女の子 and now I can't get enough of her.. |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,786 |
| Fuel pump issue | DJexor | 11 | 11,086 |
| fuel line hose from the pump | Wikizz | 4 | 8,370 |
| 4age smallport oil pump in bigport engine? | ditn | 2 | 10,249 |
12-06-2014 08:10 PM Last Post: ditn |
| Oil pump question | megabob | 2 | 6,412 |
03-05-2014 05:37 AM Last Post: oldeskewltoy |
