Need new battery it seems...
09-03-2006, 09:53 PM
Rats,
I'm getting good at pushstarting my car hehehehe.. Since yesterday I keep running into my car not starting. I still got power but not enough to make the starter go round, it tries but dies.... Yesterday I still had that after a drive when I park the car I could start it right up again but after it stood still for 15 mins no joy. But since today even after a drive it just wont start. Tonight I had the battery out of the car and in a charger for about 4 hours but that didn't do any good so I guess that rules out a problem with the alternator So its either the battery or the starter itself. Anything I can check to make sure its the battery that's gone? I need to buy a new battery anyways cause I need one for the RX7 but rather make sure I need one first... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-03-2006, 10:46 PM
Mux213 Wrote:So its either the battery or the starter itself. Anything I can check to make sure its the battery that's gone? I need to buy a new battery anyways cause I need one for the RX7 but rather make sure I need one first...Borrow mine first, just like when my battery was bad! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-03-2006, 11:24 PM
no problem to check it with my battery. Let me know if i can help you
09-04-2006, 01:59 AM
Have had same sorta problem, replaced battery but turned out to be bad starter. Bearing on rotor had gone bad(totally gone), there where small peaces of metal everywhere inside. So rotor had alot of play and touched the stator
But you have to take it out to actually check. Disclaimer: Any errors in spelling, tact, or fact are transmission errors. |
09-04-2006, 09:57 AM
Put in new battery this morning, car started up just fine... so if it doesn't die again within a week or so I'm pretty sure it was the battery
So this old battery is going into the RX7 for a little while, I only need it to test the electrics (windows/lights/etc) and it still gives enough power for that Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-04-2006, 04:53 PM
My alternator is dying. It's only charging 11.8V at the moment. Might fix that tomorow.
09-05-2006, 11:07 AM
congrats Muxie!! Hope to see you coming to the BBQ with a full battery and a working engine
09-06-2006, 04:40 PM
ZaX Wrote:My alternator is dying. It's only charging 11.8V at the moment. Might fix that tomorow. Diode bridge died on my alternator. I've put the alternator from blue spare parts car. It drives again and I have a smile on my face. Drifting - best fun you can have in your car with your pants on! |
09-06-2006, 07:39 PM
Good good zax!
09-06-2006, 07:40 PM
ZaX Wrote:ZaX Wrote:My alternator is dying. It's only charging 11.8V at the moment. Might fix that tomorow. and 2 hours later my car dies again. I think problem lies in damaged wirieing harnes, because they got burned when car was on fire after drifting incident. One of wires that goes form battery has completely burned isolation, acrost the distributor to the injector loom. I startet the car again and alternator is not chargin so I'm very sad. I will have to remove MAP wireing harness from blue parts car to silver one. I hope this alternator did not die because I don't have any more spare ones nor the money to fix that in next 2 months. Drifting - best fun you can have in your car with your pants on! |
| AE86 Battery specs | hachirokuGTV | 9 | 20,068 |
| Quick question for those who have relocated their battery.. | Jezza_hr | 10 | 13,503 |
03-06-2014 12:38 AM Last Post: rene |
| Making new wiring harness from scratch, need help | Jimmi The Kid | 13 | 29,375 |
02-10-2014 09:01 PM Last Post: Jimmi The Kid |
| Jap battery in uk? | phill 92 | 3 | 7,616 |
11-06-2012 11:00 AM Last Post: phill 92 |
| battery question | Petros AE86 | 5 | 8,509 |
10-17-2012 08:15 PM Last Post: JGeorge |
![AEU86 AE86 - Need new battery it seems... [Image: AEU86 AE86 - Need new battery it seems...]](https://www.aeu86.org/sticker-banner-468.gif)
