Need help with the air sensor
09-07-2007, 05:03 PM
Yesterday I went for a run, and when I shut down the car, (it has a turbo timer) didn’t idle, so I open the air filter and try to crank the car, but the flap inside the sensor was not working, ANY IDEAS OF WHAT THE #@#@!# Is happening with that sensor, do u have ideas on how to replace the sensor with a better technology?? How can I adjust the internal flap inside the sensor???
Regards Sergio |
09-07-2007, 05:12 PM
20V TURBO * I FORGOT
09-07-2007, 08:39 PM
? air sensor ? is it afm ? please can you post a picture ? Or is it you tps ?
09-07-2007, 09:25 PM
09-08-2007, 03:09 AM
ANY IDEAS HOW TO QUICK FIX THE PROBLEM ?
09-08-2007, 11:22 AM
I dont quite get it.. you have a turbo timer, but the engine wont idle when you switch the engine off (when the turbo timer should take over)? If it idles when you run it, it should idle with the timer too, maybe you wired it incorrectly, causing some vital thing to switch off (ignition/fuel). As I understand it, a turbo timer is nothing more than a delay between the moment you turn the ignition key to off, and the moment that the ignition is actually turned off.
| Air conditioning R134A swap | sheppardpat47 | 6 | 2,157 |
08-14-2026 10:06 PM Last Post: jomme_mega |
| Need help installing replica "OEM" sideskirts | sheppardpat47 | 3 | 1,310 |
08-09-2026 12:46 AM Last Post: sheppardpat47 |
| Windshield. Need Help. | Roma_trueno | 13 | 26,241 |
02-02-2026 02:19 PM Last Post: totta Crolla |
| map sensor cheating? | fdsjakl890 | 8 | 4,121 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Need help identifying this! | takumi_mt | 4 | 3,584 |
![AEU86 AE86 - Need help with the air sensor [Image: AEU86 AE86 - Need help with the air sensor]](http://i191.photobucket.com/albums/z2/patatusy/okok.jpg)
