Need T50 trans info
06-05-2010, 07:07 PM
Need T50 trans info
I need to know if the trans i got from the junkyards is a T50.
Came out of a TE73 corolla i belive that had no firewall plate or hood to get catalyst info, but the door jam plate said TE73 from what i remember.
the shift housing is on so i cant shift through the gears.
but
It has 21 input splines
and 20 output splines
so does this sound like a T50 or T40?
thanks
06-06-2010, 11:47 PM
Need T50 trans info
If it has a split casing and the bellhousing unbolts, then it will be
either T40 or T50. They look the same, and both will work fine. Later
model have 22 spline one end, so check your driveshaft will plug in.
Cheers... jondee86
  T50 gearbox totta Crolla 3 5,056 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 13,369 09-12-2019 07:36 PM
Last Post: DidiDex
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 7,330 11-05-2016 01:34 AM
  4A-GE bellhousing on a 20 spline T50 The Doctor 2 9,220 09-30-2016 03:38 PM
Last Post: The Doctor
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 9,026 11-27-2015 10:06 AM
