NL: Robert
07-25-2026, 06:06 PM (This post was last modified: 07-25-2026 07:06 PM by Koen.)
Post: #81
NL: Robert
Nice new parts and updates! Hopefully the car will run again soon Smile parts hoarding is always fun in the mean time. Did you buy the wing from Marktplaats? I saw someone with a yellow AE86 (SR20) selling one. The other one on MP is a copy (although the seller keeps telling a funny story about it being a prototype)
About your clutch/flywheel; I wouldn't get anything too crazy. I believe you bought a healthy 20v but it probably still will be only ~200hp. A not so strong clutch can smooth out forces in the driveline a bit for our weak gearboxes and axles. It's cheaper to replace than a box or an axle ... you can reuse your 20v one if you do some grinding to the bellhouse of your T50. Don't forget to add the spigot bearing. I do have a spare 16v original one somewhere if you want that. Or get a Toda Smile
@Banpei; they look like exact copies so I guess you still need the brackets Smile
07-26-2026, 12:16 PM (This post was last modified: 07-26-2026 12:18 PM by r.ave.)
Post: #82
NL: Robert
(07-24-2026 11:02 PM)banpei Wrote: [ -> ]They look like good copies to me! Thumbs up!
Just wondering, do these fog lights mount to the kouki lights, or do you still need the brackets for these?
Not sure, I believe the frame where the grill is mounted to already has these mounts as standard. Just need to cut out the back side of the grill
(07-25-2026 06:06 PM)Koen Wrote: [ -> ]Nice new parts and updates! Hopefully the car will run again soon Smile parts hoarding is always fun in the mean time. Did you buy the wing from Marktplaats? I saw someone with a yellow AE86 (SR20) selling one. The other one on MP is a copy (although the seller keeps telling a funny story about it being a prototype)
Haha, i'm buying your trd wing ;-)
07-26-2026, 07:06 PM
Post: #83
NL: Robert
(07-26-2026 12:16 PM)r.ave Wrote: [ -> ]
That's great. From what I remember, not all kouki EU headlights have the brackets installed. It's one of those projects on my to-do list to fabricate a copy of the OEM brackets, but as I don't own a Levin, it's always put back on the backlog.
[Image: AEU86 AE86 - NL: Robert]
07-27-2026, 01:00 PM
Post: #84
NL: Robert
(07-26-2026 12:16 PM)r.ave Wrote: [ -> ]Haha, i'm buying your trd wing ;-)
It was tempting, but I decided to stick to the plan and get a FRP/Carbon hatch in the future with the wing integrated so it's all yours Tongue
07-28-2026, 09:01 AM
Post: #85
NL: Robert
(07-27-2026 01:00 PM)Koen Wrote: [ -> ]
That is an expensive alternative, very nice though!
07-28-2026, 01:42 PM
Post: #86
NL: Robert
Also, to my knowledge and experience standard 4age starters aren't the strongest.
I have no idea if i can re-use the fwd version that is now on the engine.
So I would need a starter as well, any P&P tips for strong alternatives if the FWD version is not compatible in rwd setup?
07-29-2026, 07:56 AM
Post: #87
NL: Robert
I had a lot of problems with the starter several years ago. I bought a reductive drive starter from Seamus Mc Cooey from Premierperformancecars in Ireland. It suppose to be a starter for FWD but it fitted without problems. This starter fires the engine almost instantly.
07-29-2026, 10:50 AM
Post: #88
NL: Robert
(07-29-2026 07:56 AM)DJexor Wrote: [ -> ]I had a lot of problems with the starter several years ago. I bought a reductive drive starter from Seamus Mc Cooey from Premierperformancecars in Ireland. It suppose to be a starter for FWD but it fitted without problems. This starter fires the engine almost instantly.
Do you imply that the current fwd starter would be working on a rwd layout as well?
If so, no need to find another then
  Robert in Japan EP Importers 1 7,421 06-22-2022 11:15 AM
Last Post: EP Importers
