NL: Robert
07-25-2026, 06:06 PM
(This post was last modified: 07-25-2026 07:06 PM by Koen.)
Post: #81
NL: Robert
Nice new parts and updates! Hopefully the car will run again soon
parts hoarding is always fun in the mean time. Did you buy the wing from Marktplaats? I saw someone with a yellow AE86 (SR20) selling one. The other one on MP is a copy (although the seller keeps telling a funny story about it being a prototype)About your clutch/flywheel; I wouldn't get anything too crazy. I believe you bought a healthy 20v but it probably still will be only ~200hp. A not so strong clutch can smooth out forces in the driveline a bit for our weak gearboxes and axles. It's cheaper to replace than a box or an axle ... you can reuse your 20v one if you do some grinding to the bellhouse of your T50. Don't forget to add the spigot bearing. I do have a spare 16v original one somewhere if you want that. Or get a Toda @Banpei; they look like exact copies so I guess you still need the brackets
07-26-2026, 12:16 PM
(This post was last modified: 07-26-2026 12:18 PM by r.ave.)
Post: #82
NL: Robert
(07-24-2026 11:02 PM)banpei Wrote: They look like good copies to me! Not sure, I believe the frame where the grill is mounted to already has these mounts as standard. Just need to cut out the back side of the grill (07-25-2026 06:06 PM)Koen Wrote: Nice new parts and updates! Hopefully the car will run again soon Haha, i'm buying your trd wing ;-) |
07-26-2026, 07:06 PM
Post: #83
NL: Robert
(07-26-2026 12:16 PM)r.ave Wrote:That's great. From what I remember, not all kouki EU headlights have the brackets installed. It's one of those projects on my to-do list to fabricate a copy of the OEM brackets, but as I don't own a Levin, it's always put back on the backlog.(07-24-2026 11:02 PM)banpei Wrote: They look like good copies to me! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
07-27-2026, 01:00 PM
Post: #84
| NL: Robert | |||
07-28-2026, 09:01 AM
Post: #85
| NL: Robert | |||
07-28-2026, 01:42 PM
Post: #86
NL: Robert
Also, to my knowledge and experience standard 4age starters aren't the strongest.
I have no idea if i can re-use the fwd version that is now on the engine. So I would need a starter as well, any P&P tips for strong alternatives if the FWD version is not compatible in rwd setup? |
07-29-2026, 07:56 AM
Post: #87
NL: Robert
I had a lot of problems with the starter several years ago. I bought a reductive drive starter from Seamus Mc Cooey from Premierperformancecars in Ireland. It suppose to be a starter for FWD but it fitted without problems. This starter fires the engine almost instantly.
07-29-2026, 10:50 AM
Post: #88
NL: Robert
(07-29-2026 07:56 AM)DJexor Wrote: I had a lot of problems with the starter several years ago. I bought a reductive drive starter from Seamus Mc Cooey from Premierperformancecars in Ireland. It suppose to be a starter for FWD but it fitted without problems. This starter fires the engine almost instantly. Do you imply that the current fwd starter would be working on a rwd layout as well? If so, no need to find another then |
| Robert in Japan | EP Importers | 1 | 7,361 |
06-22-2022 11:15 AM Last Post: EP Importers |
![AEU86 AE86 - NL: Robert [Image: AEU86 AE86 - NL: Robert]](https://www.aeu86.org/sticker-banner-468.gif)
