My little (not really...) project - Soon to be all done?!?
11-24-2011, 08:58 PM
Post: #481
The second box just got in today straight from the UK Thumbs up!
[Image: AEU86 AE86 - My little (not really...) p...ll done?!?]
Yeah the high mid end is quite good but it needs a better exhaust to free the last 10 hp at 7.5k rpm Cool And since my old exhaust broke at the last trackday I might do something about it Smile
However I do believe that the new gearbox will do more good than a bit of extra power Smile
11-25-2011, 12:36 PM
Post: #482
A gearbox with good gear ratios can disguise a bad engine (which is not the case) and a gearbox with bad gear ratios can ruin a good engine.
Keeping the AE86 alive!
12-17-2011, 12:01 PM
Post: #483
Yummie! awsom som day you will get it back on the street rightSmile lol
12-17-2011, 11:09 PM
Post: #484
It is, Mikkel - well not now durring the winter - but it has been running all season. Including two trips to the Nürburgring Wave
01-05-2012, 12:30 PM
Post: #485
Yep it is.
Okey sweet i hope the 6speed Will work then i want one alsoSmile
06-18-2012, 06:45 PM
Post: #486
T50
Lexus IS200 AZ6
T50 clutch housing:
AZ6 clutch housing:
Final measuring...
...Before milling:
To be continued...
06-18-2012, 09:08 PM
Post: #487
why you just make adapter plate between is stock is bellhouse and a engine. not hard to do and you dount need to ruin t50-a engine bellhouse
i do whit stock is bellhouse and adapter
06-19-2012, 10:34 AM
Post: #488
Thats not possible or at least very hard to do. There aren't enough room for the bolt heads...
My friend Martin did make an adaptor for his 3SGE AZ6 which has a bigger housing... And that wasn't easy either :wink: It is working, though, and the 3, 4, 5, 6 are layed out real nice for the Ring Hurray!
06-19-2012, 06:56 PM
Post: #489
very easy to make adapter. just use the bigger genuine is200 bellhouse and then from alumium make adapter to engine. bolt the aluminium to block and then holes to fit is200 bellhouse to it.
IF i could do it in my garage every one else can to. Good drill and some saw to cut shape. Measure measure and cut onse.
06-19-2012, 06:59 PM
Post: #490
  Ivan's coupe: bodywork is done Ivan141 676 946,797 08-07-2024 08:46 AM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,986 06-28-2022 09:17 PM
  OST-066: I get all wavy (4AC content) oldeskewltoy 10 18,554 04-03-2020 04:29 PM
Last Post: Power_uP
  d3nso's little AE86 N2 build d3nso 27 38,907 11-13-2017 11:42 AM
  Doc's KE20: - really coming together now The Doctor 548 580,182 08-03-2011 11:57 AM
Last Post: The Doctor
