My Tuned AE86 project
09-12-2009, 02:41 PM
So how do you fit the gearbox??? Well, I took another route and decided to get an engine for it since it was lonely.
![]() Picked up my new engine today - who says you can't fit a SR in an 86? :o ![]() For those who don't know, this is a SR16VE. 86mm bore, 68.7mm stroke rod ratio of 2.11 (~4000fpm@9000rpm) 11:1 compression ratio 200/280 camshafts (low/high camlobe) ~175hp Nissan rated ~130kg More images ![]() Ports look good - although not downdraft it seems similar to a smallport somewhat. ![]() ![]() VE port is tad bigger than a smallport ![]() Makes you wonder what they were thinking with the BIGport. ![]() |
06-26-2010, 09:30 PM
anything happening with this build?
The AZ6 swap is very interesting! ![]() Patrick - MFactory Competition Products THE Replacement for Displacement! -- http://www.teammfactory.com -- |
07-04-2010, 01:54 PM
Unfortunately been busy building a house to take on any major project. At the moment its just s2000 cluster and 20v conversion
![]() Once I move my gear over to the new garage I can begin to make a new mess. |
