Corolla Won't crank/start
08-21-2011, 09:29 PM
My Corolla was sitting for a month while I was doing brake stuff. Today I can't get it to crank.
I'm assuming it's the starter, but I don't know why it would have issues when it was fine a month ago. The fuel pump comes on. Battery is good, i.e. light, blower, radio etc. - I jumper the clutch pedal switch to make sure that wasn't the issue. I tow it up this little hill where it was park and tried to clutch start with no success. But I figured that would be tough as it's kinda hard starting anyway, and it's been sitting a month. Where should I be checking first to figure out why it's not cranking?? - Should I check wiring somewhere? I checked fuses and they are good. |
08-21-2011, 10:48 PM
hit the starter with a metal pole, worked fine for me for over 3 years
No Smorking AE86 |
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 3,027 |
| Warm start problem | DJexor | 5 | 4,510 |
03-09-2023 10:15 AM Last Post: Ivan141 |
| AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 23,779 |
| Weak spark, doesn’t start. | AlexFourTwenty | 4 | 18,202 |
| Won´t start | AlexKTM | 6 | 20,145 |
12-04-2017 10:05 PM Last Post: banpei |
