My Drift project - 83' Trueno coupe
08-25-2010, 11:47 PM
Post: #131
realy cool project Thumbs up!
10-26-2010, 04:51 PM
Post: #132
Finally some more progress... Been super busy last few month with work and with new garage - so Trueno was standig still... BUT - Intake mani and exhaust mani is 98% done now Smile Intake need vacum fittings to be drilled / fixed in, and exhaust needs just supports to be done. For now - it will be ok - cuz i will be able to start working on whole front, with IC / Radiator / oil cooler and etc to get fitted in the V-mount...
[Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]
This is how it looks inside the plenum:
Ex-owner of JDM 83' Trueno Coupe
DCw Classic, classic cars restoration,
JDM wheels & parts import, sales.
http://www.facebook.com/DogCustomWorks
+37067170000
11-29-2010, 10:28 PM
Post: #133
Finally - WHOLE weekend of work on Corolla only Big Grin Managed to get some stuff made... Started to work on V-mount setup. First - Radiator / oil cooler supports:
Next - was intercooler brackets and IN / OUT pipes rework... Aint finished IN / OUT pipes - this will have to wait till next weekend Big Grin But atleast first lines of the V-mount are already visible!
Whole supports made from SSteel - to avoid corossion. Everything is removible (exept lower support) so just in case of "somthing" can be easily changed Smile
+37067170000
11-29-2010, 10:45 PM
Post: #134
Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Tongue Tongue Tongue Tongue Tongue Tongue Tongue Respect! Respect! Respect! Respect! Respect! Respect!
Don“t Think About The Past,
Live In The Present And
Dream About Tomorrow
11-30-2010, 07:50 PM
Post: #135
Thumbs up! dying to see this thing going. looks really good.
12-01-2010, 07:52 AM
Post: #136
Look great Wink
keep it up Wink Thumbs up!
SR Team
BURN THE RUBER NOT YOUR SOUL!
12-02-2010, 10:42 AM
Post: #137
So cool!
http://86life.wordpress.com/
12-06-2010, 09:05 PM
Post: #138
looks SICK.. loving the colour.
keep up the good work . Thumbs up!
Coupes, hoops and loops
12-06-2010, 11:07 PM
Post: #139
looks cooooool mateeeee
12-07-2010, 10:38 PM
Post: #140
More progress today Big Grin Finally started working on Fuel tank. As i wanted my fuel tank to be right between rear strut towers - so i had to build it by my self cuz i could not find anything Off the shelf awailible in the size / shape i wanted.
Rolled up some Aliuminium 2mm sheet - and stared messuring / bending. Made the main shape of the tank. Started to work on the place where the fuel pump will be - started rolling a tube from aliuminium,and then decided i will just jump to "home depot" kinda store - to get some bending joints for the bariers in the tank. While i was in the shop - i thought why not take a look at the kitchen things shelf. And woala - found the RIGHT shape "tube" already made for my Fuel pump to sit in Big Grin Came to garage with huge smile Big Grin
Did some modification to already pre-made "thing" Big Grin
Did some simple barriers with bending joins inside the tank - they will keep the flow more in the place - and allow fuel pump place not to starve without fuel. I will be running external pump also, along with the swirlpot - so this IN TANK stuff is not so much important..
Made a place in tank where to weld fuel pump place (made it around 1cm lower then everything)
And heres the outcome Big Grin
Put the top on - and started all the welding (actually all the welding was done by my friend - he knows how to deal with ALu stuff...)
Done for today. Tomorow - will have to make opening for the fuel pump, make a braket for the fuel pump, all the IN / OUT lines, and fill up neck Big Grin Also - the breather...
+37067170000
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 17,528 10-07-2018 09:45 PM
  Trueno Coupe South Africa MIGGZFSU 151 125,813 06-07-2018 09:40 PM
Last Post: MIGGZFSU
  Scuderia rollator CE86 trueno project NoHachi 136 172,066 04-15-2013 05:53 PM
Last Post: [Walaki]D`Lair
  Ae86 Levin drift project. filip.alin 7 10,973 01-20-2013 03:05 PM
Last Post: filip.alin
  my slow trueno project cfly86 38 48,095 12-12-2012 04:35 AM
Last Post: cfly86
