Mux213 Levin GTS
09-22-2004, 10:40 AM
Mux213 Levin GTS
Whats a distribution belt? If you meen timing belt, its fairly easy. There are marks on both belt and cam gears
09-22-2004, 10:51 AM
Mux213 Levin GTS
Hey Jan,
yeah timing belt and I know its fairly easy, I've read through the procedure a couple of times when I was tinkering with a CRX but I have actually never done it nor do I have a manual at this time. Most likely I will be able to do it by myself once my haynes manual is in (still looking for a toyota manual copy ) . I just want to make sure I don't do it wrong, be kinda nasty if I dont line it up correctly or dont tention it correctly. I'm also thinking about leaving the dust cover off and spray painting the camshaft sprockets in a nice metalic blue color (only front surface). Anyone know if this has any unwanted side effects? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-22-2004, 11:51 AM
Mux213 Levin GTS
As I said earlier: leaving the covers of allows debries to reach the timing chain etc etc. Unless you are building a show car i would let this particular rice boy modification pass.
Start bugging Kristian about his see-through cover, that would get you 90% of the look without the risk of ruining the engine. A wheel to steer the front of the car A pedal to steer the rear |
09-22-2004, 11:52 AM
Mux213 Levin GTS
NoHachi,
Sorry I must have missed that post ![]() @Kristian I WANT!
09-22-2004, 11:12 PM
Mux213 Levin GTS
I've only done a timing belt change when my engine was still in the shed, waiting for installation. It couldnt be more easy. First you align everything for top dead center on the nr 1 cilinder. Under the oil filler cap you should see an indentation in the camshaft when the piston is at tdc on the correct stroke. After that you just put the car in gear on handbrake, get the pulley bolt off (which can be a bitch sometimes..airtools are great for this one). Remove the tensioner, install the new belt tightly and in the correct direction. Install a new belt tensioner!
That should be it..lot easier to do on an ae86 than it is on a CRX I think. FABRICA MI DIEM, PVNC! |
09-23-2004, 07:34 AM
Mux213 Levin GTS
Hey Ivan,
Seems straight forward enough ![]() And yes, I got a new tentioner aswell
09-23-2004, 04:50 PM
Mux213 Levin GTS
Yeah, sanded and spraypainted the old grill last night! Will get pictures online when I get it back on the car.
Tomorow is APK day (dutch MOT) so wish me luck guys! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-23-2004, 04:57 PM
Mux213 Levin GTS
good luck!
09-23-2004, 06:48 PM
Mux213 Levin GTS
mux213 Wrote:Tomorow is APK day (dutch MOT) so wish me luck guys!Good luck! ![]() Mine (the mitsu) is due next tuesday. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-23-2004, 06:53 PM
Mux213 Levin GTS
Good luck...you should have a pretty good idea about what things might pop up at the MOT since you know your way around cars a bit. My main problems usually seem to be rust, tires, exhaust gasses and electronics.
Worn steering knuckles and wheel bearings arent uncommon as well if the car hasnt been maintained for a while. [edit] How could I forget the ol'exhaust...it's as if it's made of swiss chease FABRICA MI DIEM, PVNC! |
| Deaty's GTS Project | Deaty | 9 | 9,581 |
04-27-2021 06:10 AM Last Post: Deaty |
| 1985 Corolla GTS Project | mattscar | 5 | 13,329 |
01-30-2011 07:30 AM Last Post: mattscar |
| My SR5 to GTS Restoration Conversion. | Lofty | 15 | 26,542 |
09-25-2009 06:52 AM Last Post: Lofty |
| My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 25,736 |
08-05-2009 04:25 PM Last Post: Eric |
| AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 103,608 |
03-16-2009 10:02 PM Last Post: banpei |
![AEU86 AE86 - Mux213 Levin GTS [Image: AEU86 AE86 - Mux213 Levin GTS]](https://www.aeu86.org/sticker-banner-468.gif)
