Matt's "Drives as fast as it's Towed" 85 Levin Coupe
12-16-2014, 01:35 PM
Post: #31
Well of all the options i would pick either rebuild blacktop or find a 4agze later model and turbo it.
or use the internals of a 4agze with a 7 rib 4age. |
12-16-2014, 01:54 PM
Post: #32
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | |||
12-16-2014, 02:25 PM
Post: #33
NA blacktop is your way to go.
Getting power out of a boosted engine is to easy ![]() Daily Beater: Civic EG5 Work in progress Car: AE86 |
12-16-2014, 07:59 PM
(This post was last modified: 12-16-2014 08:02 PM by ditn.)
Post: #34
Dont think i would do a blacktop turbo
Sounds expensive and internals not sure if they will take it |
12-16-2014, 08:25 PM
Post: #35
Getting power out of a boosted engine is cheaper
And on that bombshell...I have a turbo'ed 7-rib 4agze for sale, interested? ;-) AE86 Levin |
12-16-2014, 09:17 PM
Post: #36
true alot cheaper
12-17-2014, 02:13 AM
Post: #37
Matt, it's Chris here, AE86 World, just found your thread, great work man!
Also, IMPULSE make a full 20v water relocation kit, one of the best on the market! We will also ship it worldwide, so don't worry! |
12-17-2014, 03:07 AM
Post: #38
(12-17-2014 02:13 AM)chrisd1 Wrote: Matt, it's Chris here, AE86 World, just found your thread, great work man! Hi Chris, Thanks for getting in touch, it's been a bit of a journey as you heard the start of it. Split between the S86 kit and some others at the moment but I'll give you a shout if I see anything. Cheers ![]() Dieter, I would be going for all aftermarket internals, only the crank would remain. H Section forged rods, lower comp pistons, Cams - there would be the Block, crank, Throttle bodies and breathed on head left from the original engine either way. The turbo kit just means I'd be looking at a GTIR plenum kit from S86, more fueling work, Turbo/ancillaries and THEN all the drivetrain stuff that comes with it. So I think I'll keep N/A for now, until such time I get bored of that and then I'll see where my bank takes me. Can't really afford the uprated box (Type 9 or W5 ![]() Could always keep the current Blacktop as a reserve build ![]() |
04-07-2016, 12:15 PM
(This post was last modified: 04-07-2016 01:34 PM by mad.matt.)
Post: #39
Time for some updates. [have also fixed the links on the first page as facebook seems to drop them after a while]
I am in progress of taking out the good, still worky bits that are no good to me, to sell on to fund my project and keep other brother's and sister's projects alive. The T50 was sold along with the Modified 20v Head with dizi and water kit and manifold to Will. The Kouki axle with double rose jointed panhard rod went to Kevin. The remaining good pistons, rods, timing covers and, oddly, head bolts (?!) went to a couple of guys from Hungary. There's still a few things that can be useful to folk: Front Brakes, Rear 4 Links, Rear Tokico Shocks and RSR Springs, 2 x 7 rib blocks, gearbox cross-member, Japanese Over Axle aftermarket exhaust with Decat, interior cluster, 20v ECU and loom, 20v Head and whatever I get when I take apart the current 20v, so I'll keep going until my canvas is clean! SO....my car is currently sitting in a council lock up, with no rear end on it, sitting on a Cask trolley (STUPENDOUSLY HANDY, BIG 8" wheels and solid construction, rolls SO easy) and tyre under the fuel tank and front end on the ground, covered in dirt and interior slightly mouldy, no gearbox and half an engine :lol: My parts bag (for a post later) is huge and heavy, but still needs more and I can't wait to get stuck in! My TO-DO feels even bigger! - Finish removing 20v, Strip, Inspect, Sell/Scrap - Measure and Cut front Subframe for F20 Sump - "Massage" Transmission tunnel for F20 gearbox and notch for shift hole - Remove dash and 4AGE Clocks ready for future clock conversion and wiring - Fitment of new axle, mate previous Prop with new one. - Tidy up engine bay - Send away for welding/Rust repairs - Strip F20 for inspection/parts replacement/freshen up AND probably much more that I can't think of right now... As she stands (or leans) at the moment: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And when the engine was still assembled and sitting pretty: ![]() ![]() |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 18,527 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 186,055 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 831,206 |
DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 6,464 |
08-13-2015 03:22 PM Last Post: DidiDex |
OST-026: "My White Hatch" | oldeskewltoy | 49 | 66,216 |
07-03-2014 11:56 PM Last Post: oldeskewltoy |
