MCNSPORT: Your chance to own a MCNSPORT AE86
07-24-2012, 11:19 PM
[Image: AEU86 AE86 - MCNSPORT: Your chance to ow...SPORT AE86]
Block is cleaned, honed and skimmed and ready for assembly
Crank has been cleaned and polished and fitted with TRD main bearings as used in the Formula Atlantic engines. This is not your ordinary raffle
Rods are cleaned and fitted with TRD bearings as well. New piston rings arrived today and engine is now ready for assembly
MCNSPORT.com
Jap, European, Drift, Drag, Circuit, Road, Race, Rally
Tel: +353 (0)2223334
Mob: +353 (0)866063716 (Darren) / +353 (0)876616567 (Peden)
E-mail: [email protected]
Web: http://www.mcnsport.com - NEW WEBSITE COMING: Feb, 2009!
07-24-2012, 11:20 PM
Got the 20v block assembled now with the TRD bearings and brand new rings
Got the Sp-Tec distributor re-location kit from Japan. Really nice piece of kit
Oil pump and water pump fitted and block is ready for paint
The head is now ready to be mated to the block once the paint drys. We are using a TRD 0.8mm as well
MCNSPORT.com
TRD 0.8mm Headgasket
Coming along nicely now...
MCNSPORT.com
07-24-2012, 11:21 PM
Aint she a beauty
MCNSPORT.com
MCNSPORT.com
07-24-2012, 11:22 PM
Exedy satge 1 kit
Ready for install
20valves new home
Tein tension rods, extra lock inner tie rods and prothane bushes
MCNSPORT.com
Update time.....
Underneath shot
Rear is fully polybushed. Brand new MCM/AVO rear coilovers fitted and panhard rod is now adjustable
Done a few more bits in the engine bay. I'm working on the simplest way possible to do a RWD water kit for this. whats we have done works out pretty good so i'll be doing a full post on what we've done and people can use it for future referance
Carpets in and cage has been bolted in properly, just seats left to finish the inside really...
Tank is in and anti roll bar fitted and polybushed
Tein camber tops on our MCN/AVO inserts
Steel braided brake lines and everything given a nice shot of satin black
Here is one of the coolest details of the car. We did a sunroof delete on it. Sunroofs are a pain in the ass with rust and leaking so we removed it complete with sliders etc and also removed the double steel skin thats there to carry the extra weight of the sunroof. We got a lot of weight out here, which is good for any performance car but what makes it better is getting weight out from the highest point of the car which is very important. Now most sunroof removal jobs mean welding in a plate ove the opening and filling it but i hate this kinda thing and i hate filler......so.......
We made a complete roof skin in FRP off another non sunroof ae86 and this will be bonded on over the existing roof
Next up is paint and i'll be doing an update soon with all the aero that is being used. Car will have everything FRP except the doors so the final weight is kept to a minimum
MCNSPORT.com
07-24-2012, 11:23 PM
shell primed....
MCNSPORT.com
07-24-2012, 11:24 PM
Inspiration for this car is my old ae86 N2 when it had the 4AG power. Amazingly this car is now the Need for Speed 86. Loved the look of this car!!
So something ive been thinking about for a while and im gonna be doing on one of our shop cars is combining our Dmax style quarter with our Runfree style overfender and it looks awesome!! Ive fitted one of my own 15x9 -16 Work Meister CR01's here and as you can see its lost in there.
After measuring the car would now need a 9inch rear wheel in -59offset!!!!Tongue
Dmax front fenders will be used also. The wide looking front arch area on the dmax front fenders is now matched by the combo rear
We will be using our Goodline style front bumper
Dmac style rear bumper. We havent decide on wheels yet but they wont be CR01's
Car will have our Runfree style sideskirts
Tickets are still available, just e-mail [email protected]
MCNSPORT.com
Little update......
So this is the first time ive sat down with a 20v in front of me and thought about the water pipe re-locate problem
There is a few different designs out there for re-location kits and i wanted to see if the original parts could be modified without buying a kit, so here is what i came up with
I fitted the engine and realised that it fits in the 86 with the heater and sensor block attached to the head if you remove the thermostat
So......
I wholesaw'd a piece of alu to make a blank for where the thermostat was and welded it up. Heater pipes were the next problem, one will work but has to be shortened to get a 90degree hose on it and clear the bulkhead. The other wont work so i welded it up
So i needed a return for the heater matrix so i used the original top rad hose position and welded a smaller tube into the original bolt on alu piece. Got some xtraflex samco hose to make a new heater hose
For the new top rad hose i used the original bullhorn head to water pump piece, cut it and turned it so that it now faces forward. I also welded in the rad fan sensor bung from the original thermostat housing bottom rad hose flange and this will switch the electric fan now as we have retained the 20v water pump system and havent needed to covert to ae86 water pump which i think is silly
So this is how the heater assembly now looks
This is how the bullhorn piece looks fitted and it clears the original 20v alternator in its original position. Now all thats left is fit a new top rad hose and a new bottom rad hose from the rear of the water pump with a couple of 90degree bends and an inline competition thermostat which will be drilled for water bypass during engine warm up
MCNSPORT.com
Photo How to add photos to your posts banpei 2 7,442 01-17-2022 10:31 PM
  what is your opinions on these head gaskets... CHOPKIN2 5 6,936 04-09-2018 05:29 PM
  KE70 - need your help! zemosh 2 6,225 03-19-2015 07:42 PM
Last Post: willy
  Need your help,looking for a rallcar thats looks like this ditn 17 22,913 04-11-2013 07:13 PM
Last Post: ditn
  Camshafts... what is your desire? oldeskewltoy 9 10,235 03-23-2013 02:41 PM
Last Post: Uzelac
