Longer wheel studs - Where to buy?
01-08-2008, 07:16 PM
Hi,
I need to buy longer wheel studs to fit in my AE86 so i can fit some wheel spacers. Do you know where i can buy them, preferably in Europe? I think the size is M12 with 1.25 thread... Thanks Keeping the AE86 alive! |
01-08-2008, 08:08 PM
there's a shop in germany
http://www.spurverbreiterung.de/index.php?c=true&lan=uk i don't know which one to buy, you have to meassure the diameter of the knurl first |
01-08-2008, 08:43 PM
I fitted longer wheel studs from Grand prix racewear in the U.K the only thing I would say is be a little bit careful with the length of the non-threaded portion that is pushed into the hub. On mine this section is quite long and I can no longer use the front wheels without spacers as the wheel nut will not go far enough on, the thread is not long enough.
Measure the Toyota ones in every dimension before ordering. I found it is just possible to fit the rear studs without having to remove the shafts. An analogue brain in a digital World |
01-08-2008, 09:26 PM
Quote:I found it is just possible to fit the rear studs without having to remove the shafts. I had already heard something similar... anyway since i will have to remove shafts... Keeping the AE86 alive! |
01-09-2008, 10:48 AM
| Longer wheel studs - Where to buy? | |||
01-11-2008, 02:19 PM
1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
01-17-2008, 08:56 PM
IF you need listing to conpare wheel stud measurements and thread sizes you might want to try this one
http://www.niceproducts.com.au/catalogue.../wheel.php you might find that in some countrys you already have some vehicles made by other manufactures which there standard studs are of the same measurements or longer. |
01-18-2008, 12:06 PM
I use these.. but they are not a perfect fit!
http://www.rallydesign.co.uk/catalog/pro...ts_id=4677 The holes has to be grinded ~0,3mm bigger so you can't go back to stock. |
01-18-2008, 02:18 PM
Isn't it possible to use the studs from a 200SX S13? They seem to be a bit longer and you can get longer versions everywhere. Same for the nuts.
01-18-2008, 03:35 PM
E-volve Wrote:Isn't it possible to use the studs from a 200SX S13? They seem to be a bit longer and you can get longer versions everywhere. Same for the nuts.Are'nt these the wrong thread pitch for Toyota ?? An analogue brain in a digital World |
| Spare wheel & spare wheel carrier | ondafly | 6 | 1,156 |
01-19-2026 01:00 PM Last Post: ondafly |
| ARP Head studs in a N/A engine, necessary? | Jimmi The Kid | 13 | 18,999 |
02-04-2013 11:27 PM Last Post: Jimmi The Kid |
| Longer 5th gear into T50 | stratosTRD | 3 | 6,141 |
06-16-2011 08:36 PM Last Post: stratosTRD |
| Longer studs | Eric | 4 | 7,553 |
04-29-2011 07:35 AM Last Post: Eric |
| longer wheel studs | fax0815 | 8 | 13,063 |
02-17-2011 09:57 AM Last Post: max_ae86 |
