Long boss kit
09-21-2016, 02:18 PM
Long boss kit
I'm going to replace the OEM steering wheel with a Momo one that isn't deep at all and I'm after a boss kit that will be long enough so I won't switch on the flashlights every time I turn it, like I do with the standard hubs which are being sold all over ebay (6-7cm). I need something around 10cm.
Standard wheel hubs sold all over e-bay:
[Image: AEU86 AE86 - Long boss kit]
I've found some spacers, but I don't know if they are safe.
Spacer 1:
Spacer 2:
A hub that I have found and it's 10cm long, it's from SAAS and I only find it in Australia, which is expensive too (around €120 without taxes).
SAAS wheel hub (10cm):
Another one 10cm long is from Bulgaria, made somewhere in Europe, but it doesn't fit to the AE86 as the seller said (don't know the reason).
Hub from Bulgaria (10cm):
Is there any other provider mostly from Europe, that provides long boss kits and cheep ones? I don't want to use a quick release kit either, the Chinese ones aren't safe enough.
Follow: The story of my AE86
09-21-2016, 09:31 PM
Long boss kit
I think Luisi makes a longer one, can measure for you on Friday?
09-21-2016, 10:16 PM
Long boss kit
(09-21-2016 09:31 PM)krullibull Wrote:  I think Luisi makes a longer one, can measure for you on Friday?
Yeap, that would be great!
09-22-2016, 01:45 AM
Long boss kit
Momo 7711 boss kit ? 90mm face to face. I use one of these with a 32mm
thick spacer and a flat Momo wheel.
http://www.lenkradshop.de/Momo-Lenkradna...711-Toyota
Cheers... jondee86
09-22-2016, 10:25 AM
Long boss kit
I would use the B&G Adapter or another one from Demon Tweeks rather than buy another boss tbh.
I've been trying to sell a genuine Nardi Boss from an MK1 MX5 for months Tongue
09-22-2016, 03:51 PM (This post was last modified: 09-22-2016 04:00 PM by FanIsHere.)
Long boss kit
(09-22-2016 01:45 AM)jondee86 Wrote:  Momo 7711 boss kit ? 90mm face to face. I use one of these with a 32mm
Cheers... jondee86
So 90mm plus 32mm spacer? 122mm and your hand isn't far from the indicators' switch?
I was thinking that a hub around 100mm would give approx the same space from the indicators' switch as with the stock steering wheel.
Can I have a photo of yours?
09-22-2016, 11:09 PM (This post was last modified: 09-22-2016 11:12 PM by jondee86.)
Long boss kit
Quote:So 90mm plus 32mm spacer? 122mm and your hand isn't far from the
indicators' switch?
Yes, the wheel is a long way from the indicator switch... you pretty
much have to take your hand off the wheel to reach the switch. The
reason I added the spacer was to get some more room between the
bottom of the wheel and my knees. Without the spacer I was bumping
the wheel when changing down, especially when using heel and toe.
I'm 180cm tall, but if you are less you probably don't need the spacer.
The Momo wheel is not in the car at present. I am using the Momo
boss kit with a dished Nardi wheel and a 12mm spacer.
Cheers... jondee86
09-24-2016, 08:49 PM
Long boss kit
indicators' switch?
Cheers... jondee86
I am 1.80m tall too, but I use a Sparco bucket seat and the steering wheel is adjustable in high, so it's like 2cm off my feet.
10-23-2016, 09:24 AM
Long boss kit
Forgot about this, sorry. But I have measured it now and it's 80-90mm Smile
11-14-2016, 01:22 AM
Long boss kit
The boss spacer finally arrived and made the hole set around 10cm. It was at the preferable length, but now I found out that suddenly the MOMO steering wheel I own is small enough for the AE86.
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 13,342 07-28-2022 10:48 PM
  Does anyone know where to buy a short steering hub/boss? krullibull 6 8,928 10-12-2011 10:26 PM
Last Post: krullibull
  custom boss kit Uzelac 10 14,683 08-24-2010 09:34 PM
Last Post: Apolan
  Long Stroke Springs - Espelier 40mm Tokico ??? juantonwan 20 23,396 05-11-2010 10:31 PM
Last Post: jondee86
  steering wheel/boss/quick release questions Eric 11 16,075 08-19-2008 09:35 AM
Last Post: cavey
