Long Stroke Springs - Espelier 40mm Tokico ???
05-10-2010, 02:48 AM
Really? That long ago? When I first got onto the AE86 scene 5 years ago, I could have sworn there were quite a few about
05-10-2010, 05:52 AM
AFAIK there are still Koni suspension kits available, but not for the AE86.
I made some enquiries 10 years ago when I bought my present car, and all I got from the Koni agents was blank looks If I could have bought the same kit I got the first time, I would have got another one. Instead I have had to mickey mouse around cuttings struts and trying to match components. What I have now is more track oriented and may ultimately prove to better than the Koni kit. I have to get to the track first, before I can make that call Cheers... jondee86 |
05-10-2010, 06:17 AM
Koni can supply the parts to do a full coilover kit or just dampers. They can use 30 series shocks in the rear and cut a grove for a circlip to hold the sleeve.
05-10-2010, 07:02 AM
So should I just buy some Tanabe springs? Are these the best option for something that can swap right on and work the the Tokico 5-way Illumina's?
05-11-2010, 07:19 AM
juantonwan Wrote:So should I just buy some Tanabe springs? Are these the best option for something that can swap right on and work the the Tokico 5-way Illumina's? Are stock springs okay to run with Illumina's?? Even on the stiffest setting?? |
05-11-2010, 09:15 AM
There are no Illumina for AE86, but some people put MR2/Camaro Illumina's to AE86, same as KYB AGX shocks.
Anyway, my bet is that stock springs won't be sufficient for stiff aftermarket shocks as Illumina's. |
05-11-2010, 03:55 PM
juantonwan Wrote:Not sure if coilovers are an option or not.Go for coilovers - you just can't go wrong! Fun is not the straight line! |
05-11-2010, 04:30 PM
I already have the Illumina's and have been running them, I just want to swap on a spring to run the stiffest setting.
Should I just go with Tanabe? |
05-11-2010, 04:43 PM
Yes you can, dont bother what other say about coilovers, if you use the car on the road.
Tanabe claims 2,5/2,7kg/mm which is 30% above stock springs and the F/R balance of the stock setup is kept. Lowering is 20-25mm which is still acceptable for gas shocks. I think it will be good match. Definitive better as stock 25year old tired springs. I use similar springrates (apex) and with this setup can hit also very bad (also gravel) roads without any hesitation. For occasional track use and very good roads i would choose 4/3kg/mm setup which is more understeery but stabler under gas. Shame is the espelir springs which alows the use of longstroke shocks have 40mm lowering which is def. to much. http://www.86ers.org All the hachies that Daytona can only dream about. |
05-11-2010, 10:31 PM
SekiguchiUeno Wrote:Shame is the espelir springs which alows the use of longstroke shocks There are spacers available that fit between the spring and the perch to adjust the ride height. I have seen urethane spacers (with different thicknesses) advertised in the USA. And I have heard of aluminum ones from Japan. Could be worth considering, if you can get the Espelir springs. Cheers... jondee86 |
| AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 11,067 |
07-28-2022 10:48 PM Last Post: banpei |
| HKS valve springs | totta Crolla | 3 | 3,538 |
| Long boss kit | FanIsHere | 9 | 11,654 |
11-14-2016 01:22 AM Last Post: FanIsHere |
| Springs from other vehicles?? | FanIsHere | 16 | 17,692 |
05-17-2016 09:12 AM Last Post: FanIsHere |
| 3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 7,368 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
