Levin - Trueno Questions
02-03-2012, 11:19 PM
Never knew it was for that purpose.
![]() Anyway, about the wipers: my 1982 Carina does have the wipers hidden behind the rear edge of the hood. It still boggles me why a lot of these things were already in the Carina but not on models at the same period. For instance why the EUDM AE86 had a second wiperarm. Or why the AE86 is often credited for the first Toyota with the "modern" recessed waterways at the top of the door while this was already implemented in the 1981 Carina coupe (the sedan still has the old metal canals sticking out on the side). Then again: Toyota did already put a lot of the even more modern techniques in the 1980 Soarer. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
02-09-2012, 04:19 PM
I've been reading alot about this, and talking with people about this issue...
On the Trueno version there are 3 relays for the headlights. Retract relay Retract control relay Light retainer relay Both of there 3 relays are in the scheme i've seen for the Trueno version. After that, i've searched the web for some pictures fromthis relays. Found them easily and in those pics i saw the references. Assumed them correct, went to the toyodiy to check some prices.... The weird thing is, the Light Retainer relay doesn't appear in the Japanese parts catalog, only in the US catalog. What may be this mean? This relay is mandatory in the Trueno wiring? You can see the position of the relay right above the switch. ![]() Regards |
02-09-2012, 09:04 PM
Possibly the Japanese catalogue is reflecting the Levin, no pop-up lights. Or they're out of production for so long that they've been dropped for the catalogue.
The headlight system is a nightmare, folks often throw money at it without being able to get it working. Sometimes it is the motors, the contact switches on the motors, often woring someplace that's gone bad. Honda Accords from the same year were infamous for chafing the headlight harness where it rubbed from being pulled up/down with the headlight housings. If all else fails...bypass the mess from the factory, put some switches on the dash for "up/down" and "on/off". Original owner, 1985 Toyota Corolla GT-S in the US of A. Will trade for a Cadillac-Gage V150 or a Ford GT44. |
02-09-2012, 09:21 PM
Red Wrote:If all else fails...bypass the mess from the factory, put some switches on the dash for "up/down" and "on/off".Exactly what I did after investigating the spaghetti and thought it was far less work.
02-09-2012, 09:46 PM
Well i got someone who's specialized in this issues, guaranteed!
But the weird thing, is that the relay is missing in the Japanese versions, which might lead to the big question. Is that relay useless in the whole wiring? |
02-09-2012, 10:48 PM
A friend gave me this
![]() Hmmm what exactly does this mean?! |
02-10-2012, 12:08 AM
I think that is one of Toyota's famous "some details not shown" schematics, since the real circuit also goes through the ignition switch. Not shown.
Toyota has or had a bad habit of showing partial circuits and drawing them a little differently from "western" conventions. I think the purpose of that circuit is to show you that the DOOR SWITCH is involved. When your lights are on, but you have shut the engine, the lights stay on and raised up. When the driver's side door is opened, that switch trips the light retainer relay which then shuts all the lights and drops them. Not shown or made clear from the partial schematic. And assuming that schematic is for your car. Again, Levin, Trueno, or different geographies will have different circuits depending on which lights they have and any local laws about how they may have to be configured. Unless you imported your car from Japan, the Japanese domestic parts catalogue is the wrong place for you to be shopping. Original owner, 1985 Toyota Corolla GT-S in the US of A. Will trade for a Cadillac-Gage V150 or a Ford GT44. |
02-10-2012, 12:52 AM
The only problem is where to find a Euro electrical scheme for the Trueno version!
EDIT GOT a question. Anyone here with a EURO Trueno spec would know how to answer this question. When you turn off your car and remove the key, what happens to the lights?! In my Levin the lights are independent from the engine... That's probably why that "light retainer relay" is used only in the US, when they shut down the car, the lights go off. Regards |
02-10-2012, 09:31 PM
EURO Trueno spec would be very very very very hard to find since they were never made.
02-11-2012, 12:19 AM
"That's probably why that "light retainer relay" is used only in the US, when they shut down the car, the lights go off. "
Nope, the US models don't work that way. When you shut the engine or take the key out, NOTHING CHANGES on the headlights. If you sequentially shut the engine and then OPEN THE DRIVER'S DOOR, the headlights turn out and close, when the headlight switch is in the normal (3rd) position. If it is in the fourth position, the headlights will remain UP but turn OFF. This is, by the way, considered terribly odd for headlights in the US. Traditional US headlights were never wired up to the ignition, you turned them on/off manually with a headlight switch. This because sometimes you want to shut the engine, but keep the lights on. Now, with all thenew cars having fancy headlights, automatic headlights, delayed headlights that stay on for xx seconds after you get out...I have no idea what would be normal anymore. Original owner, 1985 Toyota Corolla GT-S in the US of A. Will trade for a Cadillac-Gage V150 or a Ford GT44. |
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 9,463 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 5,278 |
| Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 11,664 |
| Brake Bias Questions | mad.matt | 10 | 17,460 |
| wider rear axle,track width,suspension questions | ditn | 6 | 13,512 |
![AEU86 AE86 - Levin - Trueno Questions [Image: AEU86 AE86 - Levin - Trueno Questions]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Levin - Trueno Questions [Image: AEU86 AE86 - Levin - Trueno Questions]](http://i41.tinypic.com/a14apv.png)
![AEU86 AE86 - Levin - Trueno Questions [Image: AEU86 AE86 - Levin - Trueno Questions]](http://img826.imageshack.us/img826/6800/ewdae861986usdmparrot42.jpg)
