Levin Coupe from Croatia - NOW SR86 with IRS
01-07-2005, 02:15 PM
Post: #71
2 ZaX:
"DIY adjustable cam pulley. "
The pulley as shown is not adjustable - I think !
01-07-2005, 02:17 PM
Post: #72
2 ian.g : from takakaira.co.jp
my m8 pero was ordering set for his ae86 so i joined.
price is around 50€.
01-07-2005, 02:19 PM
Post: #73
jamiemirror Wrote:2 ZaX:
Wrong thinking man. Wrong. Tongue
01-07-2005, 02:23 PM
Post: #74
2 ZaX - did you remove two pins from the camshaft ?
01-07-2005, 02:45 PM
Post: #75
nope, still looking for a set of cams.
Since i have 232° set of cams in my red top i'm thinking of using 240° cams from a blue top engine or going to 272° aftermarket cams.
More about cams here
http://www.club4ag.com/faq%20and%20tech_..._story.htm
01-07-2005, 02:49 PM
Post: #76
2 ZaX:
I asked becouse in your design of pulleys I cannot see how you will make offset between pin marks (holes) in the center and teeth part of the pulley (when lies the timing belt).
01-07-2005, 02:55 PM
Post: #77
OK, here's the pic off dissasembled cam pulley.
01-07-2005, 03:31 PM
Post: #78
2 ZaX: Many thanks ! I have a spare set of timing wheels and just wonder how to make them adjustable easier way :-)
01-07-2005, 10:12 PM
Post: #79
Knudsen Wrote:IMO 2 clamped swaybars doesnt have any effect atall! The only way, is to mount a stiffer one, or weld the to swaybars together. Just cut the bracket on number 2 and weld it on number 1.. Then it wouldnt look like shit either :wink:
Knudsen - it works perfectly - i also have this mod - thanxs to Zax help with another swaybar.
A lot of guys in the US & also in japan use this combo - & i can also after the cometition in Holland - tell you that IT WORK´s
Kristian
01-07-2005, 10:23 PM
Post: #80
Also made this one today.
Adjustable panhard rod. No more problems with missaligment of the rear end. I can now lower the car "properly".
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
Price = 20€.
Just waits for instalment of new bushings.
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 18,512 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 185,966 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 830,587 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 46,837 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 6,457 08-13-2015 03:22 PM
Last Post: DidiDex
