Levin Coupe from Croatia - NOW SR86 with IRS
12-14-2004, 02:33 PM
Post: #61
nice ... :-) strange the small tires under the car...
i love your car zax but you can't be serieus that the second swaybar has effect....... its taped to stay in line with the other one
12-14-2004, 02:38 PM
Post: #62
Robo, thats not a bad thing, the tape is just to keep it in place. Sway bars work on torsion strength which is caused by the metal being twisted (left side goes up, right side goes down, sway bars do nothing when both sides go up or down). So there is nothing wrong with this setup although mounting it on normal brackets will increase effectiveness, there is some slack in taping it.
12-14-2004, 04:39 PM
Post: #63
There are metal clamps on all the taped up places as well if you look carefully. Should help a little bit, but mounting a stiffer one is better.
12-14-2004, 05:34 PM
Post: #64
I'm pretty sure that 2 clamped swaybars are stronger then one aftermarket.
To support that i'm adding this chart from whiteline's web page
http://www.whiteline.com.au/docs/bulletins/010barup.pdf
01-07-2005, 12:01 PM
Post: #65
Long time no update.
DIY adjustable cam pulley.
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
cost so far - 35-40€
They should be lightnend a bit, anodyzed and maybe some markings engraved.
01-07-2005, 12:04 PM
Post: #66
Way to go Zax!
01-07-2005, 12:48 PM
Post: #67
IMO 2 clamped swaybars doesnt have any effect atall! The only way, is to mount a stiffer one, or weld the to swaybars together. Just cut the bracket on number 2 and weld it on number 1.. Then it wouldnt look like shit either :wink:
01-07-2005, 12:56 PM
Post: #68
Knudsen Wrote:IMO 2 clamped swaybars doesnt have any effect atall! The only way, is to mount a stiffer one, or weld the to swaybars together. Just cut the bracket on number 2 and weld it on number 1.. Then it wouldnt look like shit either :wink:
yo m8
effect of who clamped swaybars can be seen in THIS THREAD ! :wink:
Anyway, this is old news, new one are the adjustable cam pulleys.
01-07-2005, 01:45 PM
Post: #69
Ill still hold my money on the stiffer swaybar, or the welded one. Clamps has their limits, and they arent as strong as people might think. Some day, when the metal goes tired, they will break. And if that happens during an emergency handling, you might be fuckd :wink:
01-07-2005, 02:01 PM
Post: #70
Zax,
where to you get yor lug nuts from and how much did you pay ?
I could do with a set myself.
Regards Ian.
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 20,249 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 198,377 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 879,605 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 49,981 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 7,022 08-13-2015 03:22 PM
Last Post: DidiDex
