Levin Coupe from Croatia - NOW SR86 with IRS
01-17-2005, 01:23 AM
Post: #101
You should put the gauge somewhere where the oil is the hottest. Not the temp after a cooler.
01-17-2005, 01:25 AM
Post: #102
He refered to the pressure sender I think...and he also mentioned to put it in the line TO the cooler...still not ideal, but better than after the cooler.
01-17-2005, 02:32 AM
Post: #103
I was refering to the oil temp. gauge.
Im mounting it as close to the engineblock as possible before the oilcooler.. I know that the best place to mount it is in the oil pan, but i hope that this works just as good. Afterall the outtake to the oilcooler, should be the place where the oil is the hottest.
01-17-2005, 11:03 AM
Post: #104
Ian.G Wrote:how much trimming was required after you'd removed the spinning air vents ? I guess they are 52mm gauges yes ? I spent an hour triming the dashboard with dremel tool. Oil temp sender will have to go to the oil pan. Still no idea where to put oil preasure sender because it's bit big and bulky. Drifting - best fun you can have in your car with your pants on! |
01-21-2005, 06:49 PM
Post: #105
T peice
![]() Left: OEM presure sender Right: VDO presure sender Drifting - best fun you can have in your car with your pants on! |
01-21-2005, 06:56 PM
Post: #106
So I see you're following my suggestion...should work just fine since I didnt think it up myself
01-25-2005, 01:24 PM
Post: #107
ZaX new rice parts.
01-25-2005, 04:25 PM
Post: #108
My valve covers and sump remind me of this....
01-25-2005, 04:30 PM
Post: #109
One pic for my friend mux.
01-25-2005, 04:37 PM
Post: #110
Zaxyour going so well great project where you get oil pan is it new?
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 22,174 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 212,776 |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 926,028 |
| Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 53,922 |
04-07-2016 12:15 PM Last Post: mad.matt |
| DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 7,593 |
08-13-2015 03:22 PM Last Post: DidiDex |
Im mounting it as close to the engineblock as possible ![AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS [Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]](http://www.hr-a.com/forum/images/public/img-1106263141.jpg)
![AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS [Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]](http://www.hr-a.com/forum/images/public/img-1106686920.jpg)
![AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS [Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]](http://www.hr-a.com/forum/images/public/img-1106686921.jpg)
![AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS [Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]](http://www.hr-a.com/forum/images/public/img-1106686922.jpg)
