Leaking sunroof...
01-30-2005, 10:58 PM
Leaking sunroof...
Does anybody know where i could find the rubber seal for my pop-up sunroof? It started to leak when it's raining. The type is
FARMONT TECHNIK
Type : JUWEL
KBA 9306
If i can help you a Farmont dealer in Athens said that the code for that is 1320 but he doesn't have it and he won't have it in the future. Crying
Anybody can help? Dumb question
Thanks in advance Respect!
01-31-2005, 10:47 AM
Leaking sunroof...
Join the club man...I have a Farmont roof as well, it leaks like hell and there is little I can do about it.
01-31-2005, 12:00 PM
Leaking sunroof...
Ivan do you know if it's possible to swap my sunroof with the electric one from a donor car GTS TRUENO?
It seems to have the same dimensions with mine (measuring then on the cars).
Have you ever heard of such a project?
01-31-2005, 01:03 PM
Leaking sunroof...
Nope, but I think it's a bit difficult. You can only install it if the existing hole in your roof is smaller or exactly the same size. I think it folds under the roof so there might be some more room under the roof on models fitted with it.
01-31-2005, 01:27 PM
Leaking sunroof...
Ok Ivan!
Thanks a lot anyway Thumbs up!
  Sunroof clips FanIsHere 0 5,587 08-19-2016 11:33 PM
Last Post: FanIsHere
Bug brake line leaking - how to fix ? MC_JP 2 6,559 04-28-2014 09:47 PM
Last Post: MC_JP
  Sunroof Controller Diagram Serencebey 2 6,540 02-24-2010 05:11 PM
Last Post: Serencebey
  problem again , about leaking half shaft bearing filh 10 14,740 03-22-2009 01:03 AM
Last Post: filh
  Oil leaking from top but its not broken ??? Allexz 4 7,129 05-09-2008 07:48 PM
Last Post: nikos_trd
