Koyo Bearings Part Number (Needed)
07-30-2007, 04:32 PM
Hi
Someone knows the KOYO part numbers of the bearings used in our cars? Koyo is the toyota suplier for the bearings on our car. In order to get them cheaper i´m looking for those part numbers. The rear axle is more urgent, but if someone can provide the whole thing... better. I´ll do some investigation too, if i get something i´ll add that info here. Thanx in advance ![]() Cump´s Filipe Oliveira |
07-31-2007, 03:09 AM
Hi here the numbers I have
Front wheels bearings: Outer bearing: BR1 Inner bearings: BR8 Oil seal: 16032 Rear wheels: Axles bearings: 514000 Sorry dont have rear lock ring numbers and oil seals Hope thats help |
08-02-2007, 02:21 AM
These are the details from the wheel brg kits I received today...
Bearing: KOYO DAC357245CWRS Locking Collar: FBJ 014-R (measured at 34.80 x 51.84 x 18 ) Seal: PK6492 (NAK TC 52 x 65 x 9) Hope this helps. Got pinion bearings and seals coming this weekend ![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
08-02-2007, 06:21 PM
Os7213
I´ve found those references on ebay, but they´re nothing. Maybe is the seller codes. I went to a koyo dealer today and the bearing has the code that jondee86 refered. I confirmed the other codes, but theres no locking ring at the store. Price- 155.00 plus 25% discount. If anyone is interested... (not comercial sales). ![]() Cump´s Filipe Oliveira |
08-03-2007, 09:26 AM
Nice thanks for the confirmation
Sorry for the wrong info |
08-04-2007, 11:06 AM
These are the details of the pinion bearings from Toyota :
Locking Nut: 90179-18001 Pinion Seal: 90311-38015 (HMSB 38 65 12 SXRT) Front Bearing: 90368-30002 (KOYO M86610-N HI-CAP 30 x 64) Crush Sleeve: 41231-22010 Back Bearing: 90368-34049 (KOYO HM88610-N HI-CAP 34 x 72) The seal is a bit special... here is a picture of it. ![]() I'm not sure that it will be so easy to find in your local bearing shop Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
08-04-2007, 11:42 AM
That seal of the pinion is easy to find, its same on TA-and TE carinas and corollas.
Autoparts stores have those for couple euros. But those aftermarket seals as usual, dont have that kind of lining (like that: ////////////////) on the inner lip what original seals have. It purpose is avoid oil leaks somehow .
08-05-2007, 07:25 AM
Aha... I had to get the crush tube from Toyota, so I just ordered all the
parts from the Toyota dealer to save time. Usually I get bearings and seals from a bearings shop. But I never ordered a pinion seal before, so didn't even consider going elsewhere. If I ever need another one (and I hope I don't) I'll know better... thanks BTW the "decoration" inside the seal is a factory applied bead of grease. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
12-17-2008, 02:46 AM
Has anyone the number of the two pinion bearings? My contact could not find any bearings at the part numbers above. Anyone another idea?
Thanks Martin |
12-17-2008, 07:20 AM
take a look here
http://www.toyodiy.com/parts/p_U_1984_TO..._4101.html |
| Question on Rod Bearings | mister86 | 3 | 6,106 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
| Emergency help find store with bearings france | Allexz | 5 | 7,335 |
09-12-2019 03:24 PM Last Post: Allexz |
| Something of interest to all suspension number crunchers | Bean | 1 | 5,501 |
01-05-2015 10:29 AM Last Post: Uzelac |
| Diff bearings | izanagi | 11 | 20,604 |
07-05-2014 07:29 PM Last Post: assassin10000 |
| Top mount bearings | totta Crolla | 1 | 5,051 |
01-22-2014 11:33 AM Last Post: totta Crolla |
![AEU86 AE86 - Koyo Bearings Part Number (Needed) [Image: AEU86 AE86 - Koyo Bearings Part Number (Needed)]](http://lipinhu.no.sapo.pt/sbanner.jpg)
![AEU86 AE86 - Koyo Bearings Part Number (Needed) [Image: AEU86 AE86 - Koyo Bearings Part Number (Needed)]](http://homepages.paradise.net.nz/~wjd/ae86seal.jpg)
