Koyo Bearings Part Number (Needed)
07-30-2007, 04:32 PM
Hi
Someone knows the KOYO part numbers of the bearings used in our cars?
Koyo is the toyota suplier for the bearings on our car. In order to get them cheaper i´m looking for those part numbers.
The rear axle is more urgent, but if someone can provide the whole thing... better.
I´ll do some investigation too, if i get something i´ll add that info here.
Thanx in advance
[Image: AEU86 AE86 - Koyo Bearings Part Number (Needed)]
Cump´s
Filipe Oliveira
07-31-2007, 03:09 AM
Hi here the numbers I have
Front wheels bearings:
Outer bearing: BR1
Inner bearings: BR8
Oil seal: 16032
Rear wheels:
Axles bearings: 514000
Sorry dont have rear lock ring numbers and oil seals
Hope thats help
08-02-2007, 02:21 AM
These are the details from the wheel brg kits I received today...
Bearing: KOYO DAC357245CWRS
Locking Collar: FBJ 014-R (measured at 34.80 x 51.84 x 18 )
Seal: PK6492 (NAK TC 52 x 65 x 9)
Hope this helps. Got pinion bearings and seals coming this weekend Smile
Cheers... jondee86
08-02-2007, 06:21 PM
Os7213
I´ve found those references on ebay, but they´re nothing. Maybe is the seller codes. I went to a koyo dealer today and the bearing has the code that jondee86 refered. I confirmed the other codes, but theres no locking ring at the store.
Price- 155.00 plus 25% discount.
If anyone is interested... (not comercial sales).
Cump´s
Filipe Oliveira
08-03-2007, 09:26 AM
Nice thanks for the confirmation
Sorry for the wrong info
08-04-2007, 11:06 AM
These are the details of the pinion bearings from Toyota :
Locking Nut: 90179-18001
Pinion Seal: 90311-38015 (HMSB 38 65 12 SXRT)
Front Bearing: 90368-30002 (KOYO M86610-N HI-CAP 30 x 64)
Crush Sleeve: 41231-22010
Back Bearing: 90368-34049 (KOYO HM88610-N HI-CAP 34 x 72)
The seal is a bit special... here is a picture of it.
I'm not sure that it will be so easy to find in your local bearing shop Undecided
Cheers... jondee86
08-04-2007, 11:42 AM
That seal of the pinion is easy to find, its same on TA-and TE carinas and corollas.
Autoparts stores have those for couple euros. But those aftermarket seals as usual, dont have that kind of lining (like that: ////////////////) on the inner lip what original seals have. It purpose is avoid oil leaks somehow Smile .
08-05-2007, 07:25 AM
Aha... I had to get the crush tube from Toyota, so I just ordered all the
parts from the Toyota dealer to save time. Usually I get bearings and
seals from a bearings shop. But I never ordered a pinion seal before, so
didn't even consider going elsewhere. If I ever need another one (and
I hope I don't) I'll know better... thanks Smile
BTW the "decoration" inside the seal is a factory applied bead of grease.
Cheers... jondee86
12-17-2008, 02:46 AM
Has anyone the number of the two pinion bearings? My contact could not find any bearings at the part numbers above. Anyone another idea?
Thanks
Martin
12-17-2008, 07:20 AM
take a look here
http://www.toyodiy.com/parts/p_U_1984_TO..._4101.html
  Question on Rod Bearings mister86 3 4,797 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 5,692 09-12-2019 03:24 PM
Last Post: Allexz
  Something of interest to all suspension number crunchers Bean 1 4,583 01-05-2015 10:29 AM
Last Post: Uzelac
  Diff bearings izanagi 11 17,787 07-05-2014 07:29 PM
Last Post: assassin10000
  Top mount bearings totta Crolla 1 4,155 01-22-2014 11:33 AM
Last Post: totta Crolla
