Kouki to Zenki Levin grill conversion?
07-04-2023, 07:53 PM
Hi folks,
I bought new headlights and a zenki levin grill from flos.ie, and quelle supris, they don't match up. the headlights come complete with foglamp brackets which have two holes each side to match with the later kouki grill. Has anyone done this conversion could post a few pics of how it was done? I'd like it to fit nicely and not rely on cable-ties
07-04-2023, 09:35 PM (This post was last modified: 07-04-2023 09:36 PM by banpei.)
I can't recommend doing it with zip ties through the kouki mounting points:
[Image: AEU86 AE86 - Kouki to Zenki Levin grill conversion?]
This was done on a car I recently visited and it just didn't look right. As you can see it didn't line up correctly with the headlights.
However, r.ave did the same thing and for him, it worked:
So maybe he can shed light on his magic trick. Wink
07-05-2023, 08:41 AM
I did it recently, Banpei shared my car above.
I bought a new grill from flos (assuming they are identical with the OEM ones).
The middle bottom mounting point worked for me, the top one i took off.
Then used 2 zipties on the sides to secure it.
07-05-2023, 11:59 AM (This post was last modified: 07-05-2023 12:01 PM by Mylesmck.)
Thanks guys, I think, from my Research, that the original zenki headlights have grill mounting holes on tabs on the lights themselves. I'll have to investigate further. I prefer the look of the early grill, but I'd prefer either no grill or the kouki grill over the slated one if it's not sitting right
@r.ave yours looks perfect
07-05-2023, 02:09 PM
I used them with Kouki lights
I'll make pictures when i'm with the car
This is the one I used
Zenki grill - flos
02-07-2024, 11:00 PM
if you have fog lights, you have to dremel out a bit of the material from all of the slots on the engine side of the zenki grill (except the lower one)
it will fit nice, just use the original grill tab points and zip ties
https://www.instagram.com/p/CnzTV8zI2NR/?hl=es
02-08-2024, 10:30 AM
I Wish I had those fog lights
  20v Blacktop conversion.... Mylesmck 0 1,654 04-29-2024 05:48 PM
Last Post: Mylesmck
  Radiator & grill support panel (Levin) FanIsHere 5 4,376 11-14-2022 10:07 PM
  AFM to Map Conversion ps13michi 3 5,840 01-06-2022 10:34 AM
Last Post: ps13michi
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 13,943 12-19-2021 11:58 PM
Last Post: gh0st
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 9,406 11-05-2021 08:17 PM
Last Post: gh0st
