Koen's 86 - every drive a new issue
07-04-2025, 05:12 PM (This post was last modified: 12-19-2025 02:29 PM by Koen Bongers.)
So I've decided to start a project thread since I like these forums and participating keeps them alive (at least a bit Angel). I don't post much because I usually forget to take pictures. But here's a try Smile
This was my first AE86. Bought it from marktplaats.nl after someone added an advertisement without pictures but a text that could be an 86. Got it from an older gentleman who imported it from Germany as a crashed car in 1985. He fixed it, drove it and sold it in 2009 (to me).
[Image: AEU86 AE86 - Koen's 86 - every drive a new issue]
I kept it for about 2 years and then sold it through this forum in december 2011. Big mistake, huge regrets but other priorities Banging head
So it took a few years to get another one but eventually I did in december 2021. Exacly 10 years later (as predicted https://www.aeu86.org/forum/Thread-te-ko...#pid128681 ) I got the green Levin 3-door.
Took it home and drove it off the trailer and it broke down. Never really found the real fault but it led to some escalation so in the last 3 years it was in the workshop being fixed so I was able to take a picture at the same gasstation in 2024.
Went to the dyno to make it run properly again
So it could do this
And it was finally ready to drive again this year. It survived it's first long drive to 86Dach (no picture since I forgot to take any Sleepy) and of course I found some new issues.
To do list;
- plug holes in the firewall so rain stays outside
- move the rear-axle a bit to the left so the right tire should stop rubbing
- find and fit a TRD-style wing (or even better; a complete fiber hatch with the wing integrated)
- find and fit kouki headlights
In the mean time I wanted to go to 86Fest with my own AE86. The green car was still in pieces (and very uncomfortable) so the best solution is then to find another one. With the help of a fellow 86 enthousiast I found a clean and pretty original example in Belgium.
Bought it on 15 august 2024, got it registered, APK/TUV/MOT and took the gamble and drove it to Ireland 2 weeks later. It survived Smile did the 'parade lap' and after fitting new injectors at Flo's it was able to make it back to the Netherlands Smile
After that I had some time this winter to fix all the issues found. New brake pads/seals, new shocks + springs and a new exhaust
After another testdrive new issues were found and added to the to do list;
- install new valve-seals
- find and fit 14x7 ~ET0 Watanabe/Minilite/Superlite or similar wheels
- paint new bootcover without holes for the spoiler
- fit new fuel-level-sender
- connect radio
- find a Trueno
07-05-2025, 02:16 PM
I took one photo of your green car at 86 Dach:
The new Panda Silver two-door has an older license plate. I assume it had been registered in the Netherlands before during the mid-1990s?
07-05-2025, 05:08 PM
(07-05-2025 02:16 PM)banpei Wrote:  The new Panda Silver two-door has an older license plate. I assume it had been registered in the Netherlands before during the mid-1990s?
Yes, it's most likely a German car which was imported to the Netherlands at some point. The previous owner bought it in NL but never registered the car. I got the Dutch registration back when it was re-activated. Looks better than the new combinations so I'm quite happy with that coincidence Smile
Did something today because rain is expected tomorrow and I want to attend JCS.
Been searching for "original" boots but it's difficult to find someone who has them in stock. MaxxECU has something with the correct dimensions but no Dutch dealer is responding to my e-mails. So had to butcher something together to prevent most of the water from entering the cabin.
Its two rubber pieces drilled with a holesaw. 4 holes and a few ty-wraps keeps them in place. Not perfect, but it will prevent water splashing over my wiringloom so it will do for nowSmile
07-10-2025, 11:56 AM
Thanks for the writeup, it's an interesting story
07-17-2025, 05:04 PM
How do you exchanged the green number plates to small one?
07-18-2025, 09:22 AM
(07-05-2025 05:08 PM)Koen Bongers Wrote:  Did something today because rain is expected tomorrow and I want to attend JCS.
Can't you buy just a case of generic 'grommets' or in all different sizes?
Found them even on bol.com. Maybe search for 'blind stoppen'
07-20-2025, 01:00 PM
(07-17-2025 05:04 PM)oldskull Wrote:  How do you exchanged the green number plates to small one?
The small one's are show plates. I don't use them on public roads Hypocryte
(07-18-2025 09:22 AM)r.ave Wrote:  Can't you buy just a case of generic 'grommets' or in all different sizes?
Probably, the hole is quite big (~55mm) so the generic cases usually don't carry them and I want a proper feedthrough for the wiring.
This is wat I want: https://www.maxxecu.com/store/engine-con...ewall-22mm It's probably also a generic item from some brand, but haven't figured that out yet Smile
07-21-2025, 02:17 PM
Available in NL:
https://dp-engineering.nl/products/bushi...ewall-22mm
https://www.cbsracingshop.com/nl/bushing...mm-maxxecu
07-22-2025, 03:54 PM (This post was last modified: 07-22-2025 04:05 PM by Koen Bongers.)
(07-21-2025 02:17 PM)Ivan141 Wrote:  Available in NL:
Not in stock unfortunately (well, DP has one if you add them to the cart, but I need two). E-mailed them both, never got a reply. My temporary solution works, so I'm not in a hurry anymore Smile Thank you for searching!
So, I want to fit different wheels to the silver car. 15" is too big and the offset is pretty high (+15)
I've found some 14x7 ET -5 SSR's. Not the Watanabe (alike) wheels I actually want, but they are hard to get in the correct size, silver color and timeframe so this should do.
Any opinions about if they will fit? Stock arches, no rolled lip (and not planning to do so), ~40mm drop and I guess I'll run 185/60R14 tires.
07-22-2025, 05:33 PM
I had 15" 8J ET0, fitted just fine under stock body
  all wheel drive 3SGTE corolla qwoson 3 6,118 03-23-2008 01:50 PM
Last Post: Gtsi-R
