Kaaz 1.5 way Diff - Driveshaft Compatability
05-09-2021, 07:57 PM
Hi all, my kouki jap spec 86 has a standard diff with no lsd. I've decided to go with a Kazz 1.5 way diff. Do I need to measure the shaft first prior to ordering?
I'm aware the zenki drive is different but is there anything else I need to check compatability wise?
05-10-2021, 01:02 PM
The axle shaft are the only things you need to check. Everything else is the same as long as it's an AE86 rear end (6.7" ring and pinion).
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 12,901 07-28-2022 10:48 PM
  Help needed: is it 1 way or 1.5way LSD Dino86 2 5,084 05-17-2019 09:08 AM
  Tomei 16V poncams + Tomei technical trax 1.5 way LSD Lt86 22 26,688 09-16-2016 09:56 PM
Last Post: Alex170984
  Driveshaft free play thanos 6 12,063 02-25-2015 02:10 AM
Last Post: thanos
  Driveshaft question DidiDex 3 7,132 02-12-2015 09:43 AM
Last Post: DidiDex
