KYB AGX part numbers
06-30-2009, 12:33 PM
Trying to help a mate out and sort some adjustable dampers for his 86.
Just trying to get some prices on KYB AGX shocks as there is a company locally to me that are the main retailers in the UK.
I gave them the following details ...
90-95 SW20 MR2 front inserts
part # 765015
and
82-02 Camaro rears
part # 743019
Only issue is the pt number for the 82-02 Camaro rears dont show up on their system. The guy called KYB direct and they advise its not a valid part number?
Can anyone else confirm if I have the pt number right?
Cheers
James
[Image: AEU86 AE86 - KYB AGX part numbers]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
07-01-2009, 07:40 AM
Camaro rears part #743019 still shows in the KYB USA on-line catalog
(http://showmetheparts.com/kyb/). But they are a USA market product
and probably not listed in other markets. I had to order mine from the
USA direct, as the local agents didn't want to know.
Cheers... jondee86
07-01-2009, 10:51 PM
Cheers for the response Jon, much appreciated!
Checked out Summit and they have the rears, and also the fronts at almost half price. Thumbs up! Need to check their shipping and international handling charges which tend to screw things up.
I presume the fronts will just slot into a set of struts already converted for coil overs?
Cheers
James
07-02-2009, 09:05 AM
I got mine from http://www.shox.com for a good price.
Rears are a straight bolt on with no mods required. Fronts drop into a
shortened OEM strut. They are about 60 mm shorter than stock, and I
cut the strut by 40 mm and used a 20 mm spacer under. The only possible
problem is that the OEM gland nut does not fit the AGX. I had to get mine
opened up a bit by a machine shop, so that they would properly "cup"
the top of the insert.
Cheers... jondee86
07-02-2009, 11:16 AM
Awesome help as always Jon!
Cheers
Cool
  part numbers on standard cams Alex170984 10 15,307 09-19-2013 02:53 PM
Last Post: pack
  Rear ae86 rear discs & pad part numbers? J-86 4 8,048 11-30-2012 06:32 PM
Last Post: J-86
  Urgent. AE86 Door hinge bolt numbers. Need help hachirokuGTV 2 6,770 09-19-2010 08:16 PM
Last Post: hachirokuGTV
  AGX dampers Eric 21 26,959 05-28-2009 02:42 PM
Last Post: Rosedrift
  VIN numbers for various AE86 versions ? Uzelac 2 6,436 10-07-2008 04:48 PM
