KAAZ LSD Loudness
04-15-2007, 04:18 PM
KAAZ LSD Loudness
HI!
I am driving with my kaaz 2 way lsd since a few days, i used castrol hypoy lsd oil. The noises from the diff in tight slow corners without gas or with little gas is very loud, is this normal? |
04-15-2007, 04:19 PM
KAAZ LSD Loudness
I´ve donethe brake in process for sure
04-15-2007, 05:44 PM
KAAZ LSD Loudness
It's to be expected. I run a kaaz 1.5 in a different car, along with a few friends. And the diff noises are clearly nothing for daily use
Very loud indeed. It's normal, it will get less noisy over time.Have you done another diff oil change after the break-in process? It's suggested... |
04-15-2007, 06:07 PM
KAAZ LSD Loudness
no i dont make a diff oil change till now, i am on a track day end april then i will make a oil change and use kaaz diff oil....
04-19-2007, 02:18 PM
KAAZ LSD Loudness
Change the oil immediately after break-in!!
A bit of judder on tighter corners is normal - it's just the plates rubbing against each other and trying to lock/unlock. |
04-19-2007, 04:38 PM
KAAZ LSD Loudness
yup.. its normal... if its to loud you can take the Cusco RS... :wink:
Ash... cange that diff oil now!!!! Believe us...
04-19-2007, 05:18 PM
KAAZ LSD Loudness
ok ok, i will do a diff oil change next week before driftday,....
KAAZ LSD Loudness
Something else... (sorry for a small topic hi-jack)
Everyone told me that a TRD 2-way diff will make strange noises at slow turns etc. But i get none The diff locks up very well, and fast. But i hear no sound from it, ever... Since it locks up good, i think it's no problem, but i was suprized after everyone telling me it's noisy as hell and i hear nothing
04-19-2007, 05:19 PM
KAAZ LSD Loudness
which oil do you use?
04-19-2007, 06:35 PM
KAAZ LSD Loudness
The Doctor Wrote:Something else... (sorry for a small topic hi-jack) But you bought used unit. |
| Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 3,432 |
05-10-2021 01:02 PM Last Post: Project D |
| Kaaz width doubt, OEM is out of car | T_AE86 | 3 | 6,373 |
04-13-2013 12:05 AM Last Post: T_AE86 |
| KAAZ 2 way LSD | Rasteirinho | 23 | 34,100 |
08-07-2011 06:27 AM Last Post: heshan |
| Upgrading no-LSD diff to LSD one | Snejk | 22 | 23,993 |
04-01-2008 04:46 PM Last Post: Snejk |
| KAAZ diff Oil ?! | AshCampbell | 7 | 10,539 |
04-04-2007 02:07 AM Last Post: kid |
