KAAZ 2 way LSD
01-01-2008, 05:08 PM
KAAZ 2 way LSD
Yes, use LSD oil. look for the LS in the name.
Like: Silkolene BOA 90LS or Valvoline HP GL-5 LS 80W-90
Here is a link to cusco 80w90 and 80w140 oil:
http://www.cusco.co.jp/en/parts_product/...d_oil.html
The 80w140 oil is for race use, big tires/load/power etc..
01-03-2008, 04:29 PM
KAAZ 2 way LSD
Well, my Evo differentials have LSD that's why i used, but i'll double check it...
Keeping the AE86 alive!
01-03-2008, 04:36 PM
KAAZ 2 way LSD
Well, i checked my oil seller webpage and it says the following
Quote:SILKTRAN SYN 5 fully synthetic gear oil is a multifunction product designed primarily for use in manual transmissions and final drive units, including road and competition limited-slip differentials.
http://www.opieoils.co.uk/p-850-silkolen...r-oil.aspx
So i think i have no problem using it but i will ask Guy, from Opie Oils.
What do you guys think?
Regards,
Pedro[/quote]
01-03-2008, 06:22 PM
KAAZ 2 way LSD
not sure about that.
But kaaz says in their FAQ page http://www.kaazusa.com/techhelp2.html
DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD.
It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid. DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly.
01-03-2008, 07:38 PM
KAAZ 2 way LSD
You're right Gon,
Guy from OpieOils said "I would check with the Kaaz manual but I believe they recomend a mineral diff oil, our suggestion would be the Silkolene BOA90ls."
I will order it immediately...
Thank you all.
01-03-2008, 08:08 PM
KAAZ 2 way LSD
gon Wrote:Kaaz LSD may not function smoothly.
Oh, a new thing i heavnt heard about kaaz lsd. lol
[Image: AEU86 AE86 - KAAZ 2 way LSD]
Cump“s
Filipe Oliveira
01-04-2008, 02:57 PM
KAAZ 2 way LSD
I had the same experience, here is my topic on this matter, you may find it interesting:
http://www.aeu86.org/viewtopic/new-kaaz-...highlight=
Now the car has about 2000-3000 km on it after the diff change and those noises are gone (hopefully for good) Wink
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
01-04-2008, 03:01 PM
KAAZ 2 way LSD
Oh, and I use "Motul 90 PA" oil...
01-06-2008, 08:25 PM
KAAZ 2 way LSD
Thanks for the info CJ...
07-20-2011, 03:55 PM
KAAZ 2 way LSD
Guys do you think generally the Kaaz is value for money on endurance/performance aspects?
Cheated on my いたずらな女の子 and now I can't get enough of her..
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 4,237 05-10-2021 01:02 PM
Last Post: Project D
  Help needed: is it 1 way or 1.5way LSD Dino86 2 5,639 05-17-2019 09:08 AM
  Tomei 16V poncams + Tomei technical trax 1.5 way LSD Lt86 22 29,306 09-16-2016 09:56 PM
Last Post: Alex170984
  Kaaz width doubt, OEM is out of car T_AE86 3 7,193 04-13-2013 12:05 AM
Last Post: T_AE86
  corolla idles way to high HELP PLEASE 86_ae86_coupe 9 13,211 12-01-2011 10:05 AM
Last Post: Uzelac
