KAAZ 2 way LSD
01-01-2008, 05:08 PM
KAAZ 2 way LSD
Yes, use LSD oil. look for the LS in the name.
Like: Silkolene BOA 90LS or Valvoline HP GL-5 LS 80W-90 Here is a link to cusco 80w90 and 80w140 oil: http://www.cusco.co.jp/en/parts_product/...d_oil.html The 80w140 oil is for race use, big tires/load/power etc.. |
01-03-2008, 04:29 PM
KAAZ 2 way LSD
Well, my Evo differentials have LSD that's why i used, but i'll double check it...
Keeping the AE86 alive! |
01-03-2008, 04:36 PM
KAAZ 2 way LSD
Well, i checked my oil seller webpage and it says the following
Quote:SILKTRAN SYN 5 fully synthetic gear oil is a multifunction product designed primarily for use in manual transmissions and final drive units, including road and competition limited-slip differentials. http://www.opieoils.co.uk/p-850-silkolen...r-oil.aspx So i think i have no problem using it but i will ask Guy, from Opie Oils. What do you guys think? Regards, Pedro[/quote] Keeping the AE86 alive! |
01-03-2008, 06:22 PM
KAAZ 2 way LSD
not sure about that.
But kaaz says in their FAQ page http://www.kaazusa.com/techhelp2.html DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid. DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly. |
01-03-2008, 07:38 PM
KAAZ 2 way LSD
You're right Gon,
Guy from OpieOils said "I would check with the Kaaz manual but I believe they recomend a mineral diff oil, our suggestion would be the Silkolene BOA90ls." I will order it immediately... Thank you all. Keeping the AE86 alive! |
01-03-2008, 08:08 PM
KAAZ 2 way LSD
gon Wrote:Kaaz LSD may not function smoothly. Oh, a new thing i heavnt heard about kaaz lsd. lol ![]() Cump“s Filipe Oliveira |
01-04-2008, 02:57 PM
KAAZ 2 way LSD
I had the same experience, here is my topic on this matter, you may find it interesting:
http://www.aeu86.org/viewtopic/new-kaaz-...highlight= Now the car has about 2000-3000 km on it after the diff change and those noises are gone (hopefully for good)
1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
01-04-2008, 03:01 PM
KAAZ 2 way LSD
Oh, and I use "Motul 90 PA" oil...
01-06-2008, 08:25 PM
KAAZ 2 way LSD
Thanks for the info CJ...
07-20-2011, 03:55 PM
KAAZ 2 way LSD
Guys do you think generally the Kaaz is value for money on endurance/performance aspects?
Cheated on my いたずらな女の子 and now I can't get enough of her.. |
| Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 3,380 |
05-10-2021 01:02 PM Last Post: Project D |
| Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 4,728 |
05-17-2019 09:08 AM Last Post: Ivan141 |
| Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 25,009 |
09-16-2016 09:56 PM Last Post: Alex170984 |
| Kaaz width doubt, OEM is out of car | T_AE86 | 3 | 6,324 |
04-13-2013 12:05 AM Last Post: T_AE86 |
| corolla idles way to high HELP PLEASE | 86_ae86_coupe | 9 | 11,439 |
12-01-2011 10:05 AM Last Post: Uzelac |
![AEU86 AE86 - KAAZ 2 way LSD [Image: AEU86 AE86 - KAAZ 2 way LSD]](http://lipinhu.no.sapo.pt/sbanner.jpg)
