Just to make sure
06-16-2007, 12:19 PM
Just to make sure
I am right in thinking that a 212mm clutch combination will fit both the 4AGE and 4AGZE on the later model AE86? If so i'm in urgent need of a Helix one.
06-16-2007, 01:09 PM
Just to make sure
Jezza_hr Wrote:4AGE Afaik only the RedTop.. All BlueTop I've seen have 200 mm Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-16-2007, 01:33 PM
Just to make sure
You can use both. flywheel and clutch just have to match...
06-16-2007, 01:42 PM
Just to make sure
I was just curious what the standard size was in hope of not having to change the flywheel.
06-16-2007, 01:45 PM
Just to make sure
standard size ae86 has 200 mm
06-16-2007, 02:11 PM
Just to make sure
Right, now, what do I go for? How much would a clutch/flywheel combo cost?
06-16-2007, 02:20 PM
Just to make sure
Would a 200mm Clutch not fit a 4AGZE? Would a 212MM Flywheel fit from an AE92 engine?
06-16-2007, 04:35 PM
Just to make sure
you can take the standard ae86 flywheel on all engines there all 8 bolts :-D just make sure you have a matching set. (212 flywheel needs 212 clutch so to see) the ae92 also has (smallport) 212mm flywheel.
06-16-2007, 04:37 PM
Just to make sure
So I could I buy a used AE92 flywheel attach it to an uprated 212mm clutch and hey presto!?
06-16-2007, 04:56 PM
Just to make sure
Jezza_hr Wrote:So I could I buy a used AE92 flywheel attach it to an uprated 212mm clutch and hey presto!? jup don't forget the cover
AE86 ex-daily |
| can i just slam a oem turbo on it ? | MC_JP | 3 | 8,007 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
| Mikuni carb help just wont balance | megabob | 3 | 7,066 |
01-01-2013 10:32 PM Last Post: allencr |
| How to make the handbrake more effective? | heshan | 8 | 15,043 |
04-27-2011 03:43 PM Last Post: heshan |
| Just bought an 86! | GotamaHuy | 3 | 5,943 |
11-18-2010 10:38 PM Last Post: banpei |
| just out of curiosity..? pt 2 | ae86driftmaster | 4 | 6,824 |
08-29-2009 03:59 AM Last Post: ae86driftmaster |
