Jdm ae92 smallport specs (4age)
02-19-2006, 05:54 PM
Hi guys
This is my first technichal post, i haved try the search mode, but i cannot find anything over the specs for this type of engine, i do know the specs from the Usdm models, but i thing that it has to be a little bit difference between those Confused
Does somebody know this??
[Image: AEU86 AE86 - Jdm ae92 smallport specs (4age)]
02-19-2006, 07:19 PM
el_chico Wrote:Hi guys
I don't think if is there any phisycal difference between the engine blocks/cylinder heads.
The main difference is in the air measuring, the USDM has AFM based and the JDM has MAP sensored system.
And the JDM has more agressive ignition map, and has no emission pack (EGR) Thats why the USDM has ~125hp anf the JDM has ~140hp.
02-19-2006, 07:53 PM
Billzilla has some things on the differences between the blocks:
http://www.billzilla.org/4agstock.htm#summary
And also this is a good page for comparing them:
http://home.clear.net.nz/pages/phil.brad...%20RWD.htm
But they don't say too much about differences between USDM and JDM (since they both are from down under Wink )
02-20-2006, 06:24 PM
thanx guys Thumbs up!
  Differential specs MatuOjav 2 940 12-03-2025 07:06 PM
Last Post: MatuOjav
  Smallport coil totta Crolla 2 3,367 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 5,587 01-17-2022 05:14 PM
  AE86 Battery specs hachirokuGTV 9 21,405 03-13-2020 04:16 PM
Last Post: Power_uP
  4A-GTE 7-rib smallport nyberrg 5 8,543 05-24-2017 09:24 PM
Last Post: krullibull
