JDM GT-Apex Trueno in the Alps #
09-03-2016, 09:45 PM
No worries, it'll be end October before I'll be back for a visit.
09-04-2016, 06:51 PM
Does anyone know a place to get an OEM to ISO radio adapter harness? Can't seem to find anything for this generation of Toyota radio connectors, just a lot for the next generation that I have in my '92 Camry DD.
09-04-2016, 08:12 PM
Welcome.
I've seen this one when it was still for sale. Looks like you bought a decent spec car.
ハチロク
[Image: AEU86 AE86 - JDM GT-Apex Trueno in the Alps #]
09-04-2016, 09:46 PM
I never found a ready adapter, so I just bought the modern plug with leads and spliced it into the existing one.
09-17-2016, 05:42 PM
So, was investigating the engine bay today and listened more intently to the engine:
After warmup when it switches to normal idle, I can hear a slight knock. Don't know yet where this comes from, but there's two options:
- The JDM ECU isn't mapped to run the stock 4age with standard 95 octane
- The engine has actually been upgraded in terms of comp ratio and/or cams
Also finally started fixing up the head lights. Also took pictures of the radio wiring harness, will try to find the proper connectors.
09-19-2016, 05:43 PM
About the noise.... Could be valves....
It can be the ECU tunning itself... It is learning new data and it will need some time....
Do you have 98oct gasoline in your place? That should do the trick. Wink
09-19-2016, 08:50 PM
(09-19-2016 05:43 PM)pack Wrote:  About the noise.... Could be valves....
Yes, was going to drain the tank and fill it with 98 octane. Valves have some play too, which I will fix when I've had a look at the cams, whatever they might be.
09-25-2016, 06:11 PM
Fired it up today, still the same 95oct in the tank. No knocking sound to be heard this time, just the normal clickering: link to video. Maybe someone with 4A-GE experience knows what these sounds are?
09-25-2016, 07:53 PM
Sound like valve clearance is too loose
Daily Beater: Civic EG5
Work in progress Car: AE86
09-25-2016, 09:05 PM
Noisy valvetrain & injectors clicking. Mine has been like that for 5 years and still runs strong.
ハチロク
  JDM BCNR33 in the Alps decryphe 3 555 08-06-2025 03:03 PM
Last Post: Koen Bongers
  Corolla KE10 in the Alps decryphe 9 3,541 10-30-2024 11:31 PM
Last Post: DarkSupra
  JDM JZA80 in the Alps decryphe 16 12,611 04-22-2024 01:25 PM
Last Post: decryphe
  Wanted: JDM zenki trueno bumper (with JDM bumper lights) gh0st 0 2,733 10-07-2021 04:08 PM
Last Post: gh0st
  Toyota Sprinter AE86 GT-Apex Trueno Skyracer 222 297,463 08-13-2016 12:46 PM
Last Post: Skyracer
