Ivan's coupe: seeing RED
10-25-2014, 10:58 PM
Post: #431
Door nr 2 is done.
Welding:
[Image: AEU86 AE86 - Ivan's coupe: seeing RED]
Much grinding:
Zink sprayed.
Some temporary paint... proper finish will be done after blasting.. there is just paint, no filler.
Check for straightness, the front end is a bit out of line, but it's nothing drastic.
I finished stripping the rest of the parts off the doors so they are completely ready for blasting afterwards.
Noticed a couple of things I will need. If anyone has any of these parts or knows if they can be bought new please let me know.
-Left front corner window trim (the bit under the mirror): spotweld holding a bit of thread came loose. Dont know if I can fix it without ruining the plastic. Industrial glue might be the answer.
-Left inner window guide rail is missing.. this should be bolted inside the rear (doorhandle) side of the door. If I cant find one I'll have to make one.
-1 of my door hinges need to be fixed up or replaced. Dont know if bottom or top hinge.
-Bottom window trim on both sides will need to be replaced or fitted with a new bottom window seal.. Old dried up ones tend to hold crud in them and cause scrapes on the windows.
10-26-2014, 10:07 PM
Post: #432
Nice work!
Did you have enough room in front of the Celica or did Berend move his Benz out of the bodgeshed?
10-26-2014, 11:57 PM
Post: #433
That's a charade back there?! :O
BEAST!
10-27-2014, 10:41 AM
Post: #434
@Banpei: The benz was out of the way so I had plenty of room.. It did dropin for it's 2-weekly repair though Tongue.
@Pack: Yes, that would be Thomas' (the Doctor) Daihatsu charade. I think it is presently very close to going to a wrecking yard due to it's automatic transmission being broken, and Doc having enough work on his hands getting the KE20 going again. The charade is not a turbo though.. he just swapped the nicer bumpers and gauge cluster on it.
10-27-2014, 02:09 PM
Post: #435
The Charade is going to a daihatsu garage, to be reborn, or to be broken for parts to keep others alive, depending on what the owner thinks of it Smile
10-27-2014, 02:15 PM
Post: #436
That's a much better solution Smile
10-31-2014, 02:02 PM (This post was last modified: 10-31-2014 02:20 PM by Ivan141.)
Post: #437
Reminder to self:
Found some partnumbers on http://toyotamarket.ru/ (online EPC with pics).
Prices as specced by Amayama.com ex.shipping.
Kouki lower window guiderail (LH):
67408 FRAME SUB-ASSY, FRONT DOOR, REAR LOWER LH
6740412041 01 1984/05-1987/04 AE8# PLANT.M21-M22 USD 21.90
6740412071 01 1984/05-1987/04 AE8# PLANT.A51-A54 USD 19.97
Weatherstrips for door windows:
Outer:
LH: 6785312010 01 1983/05-1987/04 AE8# USD 14.75
RH: 6785312010 01 1983/05-1987/04 AE8# USD 14.75
Inner:
LH: 6822012160 01 1983/05-1987/04 AE8# USD 28.10/33.25
RH: 6817012230 01 1983/05-1987/04 AE8# USD 28.10/33.25
Hinges:
Upper:
LH: 6872014030 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00
LH: 6872032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.23/32.23
RH: 6871014030 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 33.36
RH: 6871032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.23/34.24
Lower:
LH: 6874024010 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00
LH: 6874032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.04/33.89
RH: 6873024010 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00
RH: 6873032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 22.79/31.89
RH REPLACEMENT PART: 6873030090 USD 27.48/32.11
Front window corner trim LH:
75717 COVER, FRONT DOOR BELT MOULDING END, FRONT LH
7571719015 01 1983/05-1987/04 AE8#..APX,GL,GT,GTV,SR USD 19.06
11-05-2014, 04:44 PM
Post: #438
Nice link! Smile
11-05-2014, 04:48 PM
Post: #439
(11-05-2014 04:44 PM)banpei Wrote:  Nice link! Smile
Indeed pity Toyodiy doesn't show pictures anymore, used it so many times.
AE86 ex-daily
11-05-2014, 04:50 PM
Post: #440
Indeed. And I got rid of my laptop with XP on it and for some reason can't get the EPC to work on 7. Sad
Besides that: online is far more convenient. Wink
  Gtsi-R red'n black coupĂ© Gtsi-R 147 177,668 02-03-2022 02:43 PM
  Red over Black UK Ae86 RobH69 5 20,084 02-03-2011 02:01 PM
  my 1984 red over black corolla gt davegtcoupe 3 12,558 10-12-2010 08:14 PM
Last Post: davegtcoupe
  Red panda coupe...rebuilded vladx_kc 98 126,421 07-24-2008 07:08 PM
Last Post: robokill
  Red Dragon islade 72 93,956 03-01-2008 04:37 PM
Last Post: islade
