Ivan's coupe: seeing RED
03-03-2013, 02:29 PM
Post: #391
That's a lot of work!
You really could use a ( zetbankje ) to make those weld-in peaces fit tight!
Respect for this project! Thumbs up!
http://bruutt.blogspot.nl/
03-03-2013, 06:35 PM
Post: #392
Well I'm back early today so I didnt get nearly enough done for the time I was @ the garage, but that's to be expected after a long break.
You develop a knack for metal work but it takes some warming up.
Made myself an under seat floor reinforcement using CAD (cardboard aided design).
Sadly I only had enough time to finish off one for the drivers side, but I have the pattern for the other side ready and it should be done faster.
Pictures follow once the Doctor is home, I snapped some pics using his camera.
BTW Bennie... I already have a small metal bending brake. Used it today.
03-04-2013, 01:17 AM
Post: #393
Ivan, Master of Metal Tongue
[Image: AEU86 AE86 - Ivan's coupe: seeing RED]
03-04-2013, 10:10 AM
Post: #394
Thanks Doc! Hurray!
03-18-2013, 11:30 AM
Post: #395
Been at it again this weekend:
Finished off the internal 'frame rail' reinforcements:
Dreamt up some shock tower top stiffeners (shakkito plates or whatever the japs call them). I built it out of puny 1mm sheet metal instead of the 3mm thick contraptions you see being used because the thick stuff is a bitch to work on, it's heavy, and I do not intend to rally my car.
Then did some seam welding.
03-19-2013, 12:51 AM
Post: #396
nice, looks like you are starting to like the welding better then the driving Tongue
BTW will the clutch cylinder fit with all that metal there?
03-19-2013, 11:07 AM
Post: #397
It will fit without problems.. it actually sits a lot lower than the metal plate.
And even if it didnt..a remote reservoir is not so difficult to build.
I would agree on the welding fetish remark..I forgot how my ae drives a long time ago but I sure like welding it. I promise it will see paint this year (even though it might only be an epoxy basecoat to protect the blasted chassis).
Now that reminds me of another thing: I should weld a bracket for a brake master cylinder stopper to that shock tower while I'm at it...(since LHD ones are hard to find and they are usually overpriced anyway).
03-19-2013, 11:47 AM
Post: #398
Can relate to all the welding, and no driwing Wink
I also hope to get the shell finished this year, and have it Epoxy primed.
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
03-19-2013, 10:45 PM
Post: #399
Damn dude...
So what are you going to do about painting it once it's all welded up?
03-20-2013, 09:17 AM
Post: #400
Once I'm done welding I'm sending it off for particle blasting and an epoxy coat, which is about the best I can afford on my budget. After that it's time for filler and such (a.k.a troweling on the wob, as my good friend Thomas (the Doctor) likes to say).
  Gtsi-R red'n black coupĂ© Gtsi-R 147 179,220 02-03-2022 02:43 PM
  Red over Black UK Ae86 RobH69 5 20,185 02-03-2011 02:01 PM
  my 1984 red over black corolla gt davegtcoupe 3 12,620 10-12-2010 08:14 PM
Last Post: davegtcoupe
  Red panda coupe...rebuilded vladx_kc 98 127,983 07-24-2008 07:08 PM
Last Post: robokill
  Red Dragon islade 72 95,310 03-01-2008 04:37 PM
Last Post: islade
