Ivan's coupe: seeing RED
07-13-2012, 08:58 PM
Post: #351
07-14-2012, 01:33 AM
Post: #352
One will do fine for starters (now that I think of it, I donated a dubious cluster to you once, that would be a good option for experimenting).
We have to get in touch, I still need pick up my 86 stuff. Might as well combine some things.
07-15-2012, 12:33 PM
Post: #353
good point. I need to clean up that place anyway Smile
07-15-2012, 01:32 PM
Post: #354
Haven't stood still this weekend, so here's the obligatory update:
Built myself a bit of reinforcement structure between my DIY turrets.
Was a bitch of a job because I ran out of clean zincor plate to use. Had to resort to using a bit of cut up volvo 245 roof (plenty of metal there) which resulted in much time lost cleaning.
First test fit, looks like it will work:
[Image: AEU86 AE86 - Ivan's coupe: seeing RED]
Welded up:
You can spot some bits of cardboard in the last pics where I will make some more gusseting to hide the ugly corners from sight a bit more. Had hoped to do those yesterday but I ended up spending the best part of 7 hours working on that single damn bit of plate. A hydraulic hole punch would be a blessing for making those flared holes.
07-15-2012, 03:49 PM
Post: #355
Good job mate, it should have a bit of that Volvo indestructableness about it now. Smile
What is the next big job?
07-15-2012, 04:40 PM
Post: #356
Next small job is making those last few gussets for the rear and doing a proper repair to the right A-pillar where Bert made somer fucked up looking repair that is already showing rust coming from underneath.
Next and probably last big job is chopping the right rear wheelarch out, extending and fixing up the inner wheel well and welding in an escort arch.
That's a 2-full-day job in my book, and one that I will be doing with a tear in my eye because there is nothing really wrong with that arch other that not being perfectly symmetrical to the other side that's already escort arched.
After that it is mostly plain sailing, making reinforcements where I think they are necessary (jacking points anyone?), and some last little spots of rust.
07-15-2012, 05:15 PM
Post: #357
nice ivan but what kind of truck suspension are you going to run on it? I mean you can add an axle with 500hp to that structure Smile
07-20-2012, 10:02 PM
Post: #358
What's that?
[img name=]http://www.aeu86.org/files/im/img_20120714_173536_159.jpg[/img][img
Philip
07-20-2012, 10:56 PM
Post: #359
This with some old celica overfender riveted on... it's not much too look at tbh.
07-21-2012, 01:09 PM
Post: #360
Those Volvos ar savage, if I haven´t spend all the hours and money on an AE86 I´d have one of them.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
  Gtsi-R red'n black coupé Gtsi-R 147 180,159 02-03-2022 02:43 PM
  Red over Black UK Ae86 RobH69 5 20,223 02-03-2011 02:01 PM
  my 1984 red over black corolla gt davegtcoupe 3 12,647 10-12-2010 08:14 PM
Last Post: davegtcoupe
  Red panda coupe...rebuilded vladx_kc 98 128,522 07-24-2008 07:08 PM
Last Post: robokill
  Red Dragon islade 72 95,770 03-01-2008 04:37 PM
Last Post: islade
