Ivan's coupe: seeing RED
03-03-2013, 02:29 PM
Post: #391
That's a lot of work!
You really could use a ( zetbankje ) to make those weld-in peaces fit tight! Respect for this project! http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
03-03-2013, 06:35 PM
Post: #392
Well I'm back early today so I didnt get nearly enough done for the time I was @ the garage, but that's to be expected after a long break.
You develop a knack for metal work but it takes some warming up. Made myself an under seat floor reinforcement using CAD (cardboard aided design). Sadly I only had enough time to finish off one for the drivers side, but I have the pattern for the other side ready and it should be done faster. Pictures follow once the Doctor is home, I snapped some pics using his camera. BTW Bennie... I already have a small metal bending brake. Used it today. FABRICA MI DIEM, PVNC! |
03-04-2013, 01:17 AM
Post: #393
Ivan, Master of Metal
03-04-2013, 10:10 AM
Post: #394
Thanks Doc!
03-18-2013, 11:30 AM
Post: #395
Been at it again this weekend:
Finished off the internal 'frame rail' reinforcements: ![]() Dreamt up some shock tower top stiffeners (shakkito plates or whatever the japs call them). I built it out of puny 1mm sheet metal instead of the 3mm thick contraptions you see being used because the thick stuff is a bitch to work on, it's heavy, and I do not intend to rally my car. ![]() Then did some seam welding. ![]() ![]()
03-19-2013, 12:51 AM
Post: #396
nice, looks like you are starting to like the welding better then the driving
![]() BTW will the clutch cylinder fit with all that metal there? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-19-2013, 11:07 AM
Post: #397
It will fit without problems.. it actually sits a lot lower than the metal plate.
And even if it didnt..a remote reservoir is not so difficult to build. I would agree on the welding fetish remark..I forgot how my ae drives a long time ago but I sure like welding it. I promise it will see paint this year (even though it might only be an epoxy basecoat to protect the blasted chassis). Now that reminds me of another thing: I should weld a bracket for a brake master cylinder stopper to that shock tower while I'm at it...(since LHD ones are hard to find and they are usually overpriced anyway). FABRICA MI DIEM, PVNC! |
03-19-2013, 11:47 AM
Post: #398
Can relate to all the welding, and no driwing
![]() I also hope to get the shell finished this year, and have it Epoxy primed. Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
03-19-2013, 10:45 PM
Post: #399
Damn dude...
So what are you going to do about painting it once it's all welded up? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
03-20-2013, 09:17 AM
Post: #400
Once I'm done welding I'm sending it off for particle blasting and an epoxy coat, which is about the best I can afford on my budget. After that it's time for filler and such (a.k.a troweling on the wob, as my good friend Thomas (the Doctor) likes to say).
| Gtsi-R red'n black coupé | Gtsi-R | 147 | 181,644 |
02-03-2022 02:43 PM Last Post: Ivan141 |
| Red over Black UK Ae86 | RobH69 | 5 | 20,330 |
02-03-2011 02:01 PM Last Post: Bean |
| my 1984 red over black corolla gt | davegtcoupe | 3 | 12,714 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
| Red panda coupe...rebuilded | vladx_kc | 98 | 129,755 |
07-24-2008 07:08 PM Last Post: robokill |
| Red Dragon | islade | 72 | 96,870 |
03-01-2008 04:37 PM Last Post: islade |
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](http://www.ke20.nl/ivan1.jpg)
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](https://lh4.googleusercontent.com/-69AxBRq2zKk/UUbVxAvV1JI/AAAAAAAABsk/y6cxPCdW-yA/s640/IMG_20130317_165956.jpg)
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](https://lh5.googleusercontent.com/-nT6o9DTBmHA/UUbVsM5anSI/AAAAAAAABsc/8yTAdnDqQk4/s640/IMG_20130317_165946.jpg)
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](https://lh5.googleusercontent.com/-K4OuTX0jwDY/UUbViC3Ox7I/AAAAAAAABsM/sAdawFfGjrY/s512/IMG_20130317_173642.jpg)
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](https://lh4.googleusercontent.com/-uvi2xWqrYzc/UUbVnPQhtRI/AAAAAAAABsU/BCtyzIPII5Q/s512/IMG_20130317_183548.jpg)
