03-03-2013, 02:29 PM
Post: #391
That's a lot of work!
You really could use a ( zetbankje ) to make those weld-in peaces fit tight!
Respect for this project! Thumbs up!
http://bruutt.blogspot.nl/
03-03-2013, 06:35 PM
Post: #392
Well I'm back early today so I didnt get nearly enough done for the time I was @ the garage, but that's to be expected after a long break.
You develop a knack for metal work but it takes some warming up.
Made myself an under seat floor reinforcement using CAD (cardboard aided design).
Sadly I only had enough time to finish off one for the drivers side, but I have the pattern for the other side ready and it should be done faster.
Pictures follow once the Doctor is home, I snapped some pics using his camera.
BTW Bennie... I already have a small metal bending brake. Used it today.
03-04-2013, 01:17 AM
Post: #393
Ivan, Master of Metal Tongue
[Image: AEU86 AE86 - Ivan's coupe: bodywork is done]
03-04-2013, 10:10 AM
Post: #394
Thanks Doc! Hurray!
03-18-2013, 11:30 AM
Post: #395
Been at it again this weekend:
Finished off the internal 'frame rail' reinforcements:
Dreamt up some shock tower top stiffeners (shakkito plates or whatever the japs call them). I built it out of puny 1mm sheet metal instead of the 3mm thick contraptions you see being used because the thick stuff is a bitch to work on, it's heavy, and I do not intend to rally my car.
Then did some seam welding.
03-19-2013, 12:51 AM
Post: #396
nice, looks like you are starting to like the welding better then the driving Tongue
BTW will the clutch cylinder fit with all that metal there?
03-19-2013, 11:07 AM
Post: #397
It will fit without problems.. it actually sits a lot lower than the metal plate.
And even if it didnt..a remote reservoir is not so difficult to build.
I would agree on the welding fetish remark..I forgot how my ae drives a long time ago but I sure like welding it. I promise it will see paint this year (even though it might only be an epoxy basecoat to protect the blasted chassis).
Now that reminds me of another thing: I should weld a bracket for a brake master cylinder stopper to that shock tower while I'm at it...(since LHD ones are hard to find and they are usually overpriced anyway).
03-19-2013, 11:47 AM
Post: #398
Can relate to all the welding, and no driwing Wink
I also hope to get the shell finished this year, and have it Epoxy primed.
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
03-19-2013, 10:45 PM
Post: #399
Damn dude...
So what are you going to do about painting it once it's all welded up?
03-20-2013, 09:17 AM
Post: #400
Once I'm done welding I'm sending it off for particle blasting and an epoxy coat, which is about the best I can afford on my budget. After that it's time for filler and such (a.k.a troweling on the wob, as my good friend Thomas (the Doctor) likes to say).
  My little (not really...) project - Soon to be all done?!? Jan Pedersen 516 699,573 06-27-2013 12:28 PM
Last Post: T_AE86
  Another SR20DET conversion allmost done :) peter møller 7 18,214 05-04-2011 01:16 PM
Last Post: worholm
  Yay! Its now done and on the road! Black Betty 24 28,761 01-20-2006 08:12 PM
Last Post: Black Betty
  Bodywork in 3 steps max_ae86 67 76,725 01-03-2006 02:34 PM
Last Post: Apolan
