Is it worth restoring an unused AE86
03-15-2010, 11:09 AM
Ill buy it off you....
Brake with the left hand, steer with the right foot... |
03-15-2010, 12:39 PM
The only thing I could see causing a problem from storage isn't really rust but perishing of rubber components, bushes, belts, pipes, etc. Typically they become hard and brittle and may cause problems. If its been stored in a garage it shouldn't really have rusted, even so its likely to be pretty mint.
Similarly the oil / brake fluid should probably be changed because its not really meant to be used for that long and may break down or something. Once you've checked those things it should run fine. And is it really 3K from new? That blows my mind
03-15-2010, 12:46 PM
Can you upload some pics? I would really like to see how a stock hachi with so few km's looks like....
03-21-2010, 07:35 PM
I actually bought one that had been in a garage for 9 years or so. As said above rust was not a problem at all but replacement of rubber components, bushes, belts, pipes, fuel and oil filters, fluids etc will be necessary.
![]() * RaceMinded Blog * NoCarNoLife.eu * |
03-22-2010, 12:40 AM
as many have already hinted @... the mileage is the key...
I spent about 5 years in the restoration(Mustangs, and other older Fords) supply business... Personally... I would not be considering this as a regular daily... get the Fiat/Peugeot to use as a daily... this car with only 3000km makes it VERY low mileage... very low mileage means bigger value If you have some photos... post'em Since you aren't a car person... it might be of considerably more value to you sold............ Btw... what continent are you on??? Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-22-2010, 03:11 AM
gfxl Wrote:Hi, chek it from A to Z,take notes , caculate $$$ if not cool to you leave it ,but if is cool just do it 1!!!!
| Restoring original pizzacutter center caps | banpei | 17 | 12,820 |
06-24-2021 10:58 PM Last Post: banpei |
| Effects of valve lift - worth it going higher? | harkes | 18 | 20,714 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
| Is used TRD exhaust header worth ~200e ? | Uzelac | 10 | 21,832 |
04-22-2011 10:40 PM Last Post: Uzelac |
| Rotary AE86. Worth it? | someassemblyrequired | 5 | 12,149 |
05-13-2010 12:51 PM Last Post: someassemblyrequired |
| mild cams... is it worth it? | megabob | 12 | 15,090 |
02-27-2010 08:12 PM Last Post: NonStopTuning |
![AEU86 AE86 - Is it worth restoring an unused AE86 [Image: AEU86 AE86 - Is it worth restoring an unused AE86]](http://www.teamtiewrap.com/RMFiles/Barry/RaceMinded/rmsigblog.gif)
![AEU86 AE86 - Is it worth restoring an unused AE86 [Image: AEU86 AE86 - Is it worth restoring an unused AE86]](https://upload.wikimedia.org/wikipedia/commons/1/1b/New_stock_ae86_coupe.jpg)
![AEU86 AE86 - Is it worth restoring an unused AE86 [Image: AEU86 AE86 - Is it worth restoring an unused AE86]](http://img704.imageshack.us/img704/7318/serchmarclogo.jpg)
