Is drifting really faster?
09-06-2005, 03:37 PM
Watching the Initial D, people can learn a lot about fast driving. But reading the Internet, all the sites I've visited, explaining technics about the fast driving are confirming the opinion - slide/drift is loose of time. So drift should be avoided, to keep the times fast.
Takumi on the other side is showing acceleration drift, braking drift... the whole movie is about hard drifting. So where is the truth?
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
09-06-2005, 03:44 PM
the truth is,its faster. yes initial d is impossible but for a road with low quality(grip) and narrow hairpins,its faster
hahaha drifter lol
09-06-2005, 03:45 PM
Generally speaking drifting is slower...but on some tight corners, and on loose surfaces (like in rally), it can help keep the speed up.
Initial D is just a cartoon, and professional drifting is a style contest, nothing to do with taking the fastest way through a turn anymore. FABRICA MI DIEM, PVNC! |
09-06-2005, 03:46 PM
2xIvan
09-06-2005, 03:50 PM
In some cases drifting can be faster, but in most cases it makes no sense to drift through a corner while driving for speed.
In the last episode (EP 17) of 4th stage takumi uses a drift to lose speed instead of breaking early. In a normal race it would ask too much for your tires, but for a single race you can waste your tires since you only have one lap. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
Ivan141 Wrote:Generally speaking drifting is slower...but on some tight corners, and on loose surfaces (like in rally), it can help keep the speed up.but who cares right???it looks kool!!!!!!!!
09-06-2005, 03:52 PM
10x for the answers guys!
How would you comment this opinion in the context ot the friction circle Quote:Maximum traction actually occurs with a slight amount of tire slippage against the rough asphalt surface. Maximum braking occurs at 10 to 15% slippage, and maximum cornering occurs at 5 to 10% slippage, as proven by numerous engineering studies and daily racing team computer datalogging records. This maximum grip occurs because the rubber in the tire is being torn away by the extreme forces involved, although the tire must be rotating to achieve this grip. Does it means a bit of slip is good - but to dificult, do no driver can keep it on every surface? "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
09-06-2005, 03:54 PM
zeetee Wrote:Ivan141 Wrote:Generally speaking drifting is slower...but on some tight corners, and on loose surfaces (like in rally), it can help keep the speed up.but who cares right???it looks kool!!!!!!!! I care a lot!
09-06-2005, 03:57 PM
i read this somewhere last time! yes that means drifting at 10-15 degrees.. lol
09-06-2005, 03:58 PM
When you do more performance driving you'll find out soon enough what kind of slip angle works best. In my short experience I can say that you rarely get much slip on fast racing tracks in the long corners. On tight slalom tracks however the car feels best when you have a tiny bit of oversteer, you can feel it pretty well in the car, but you hardly notice it while looking at the car from the outside. That would be your 5% slip i think.
I could see on the slalom that our drifting forum members were going faster through a couple of hairpins doing full out drifts than me and mux driving grip through the same corners. On the wider stuff however it is completely pointless. FABRICA MI DIEM, PVNC! |
| Drifting with stock power on the dry | AshCampbell | 47 | 78,092 |
05-23-2012 02:22 PM Last Post: phill 92 |
| Best setup for drifting... | Okami | 68 | 116,475 |
01-19-2012 11:20 PM Last Post: Okami |
| Drifting Lelystad New Vid check bottom | Okami | 9 | 20,174 |
03-14-2011 10:47 PM Last Post: Okami |
| DRIFTING IN ROMANIA | spawns | 5 | 11,828 |
09-09-2010 01:32 PM Last Post: spawns |
| Indie feature documentary on drifting – calls for stories | emptykingdom | 2 | 10,615 |
05-18-2010 12:05 PM Last Post: Okami |
![AEU86 AE86 - Is drifting really faster? [Image: AEU86 AE86 - Is drifting really faster?]](https://www.aeu86.org/sticker-banner-468.gif)
